Archives de la liste
- To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] support for cudaMemcpyPeer
- Date: Sun, 25 Mar 2018 00:09:33 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hatem Ltaief, on sam. 24 mars 2018 13:52:01 +0000, wrote:
> You are right, I have omitted the dyn libs. So, it is there
How is it there exactly? Please send the nm output :)
There is no reason why we should use -lcudart_static.
That being said, I just dropped that detection, it can only pose problem
whenever NVidia does tricky things with the symbol, and nowadays we can
safely assume by default that it is available.
Samuel
- [Starpu-devel] support for cudaMemcpyPeer, Hatem Ltaief, 24/03/2018
- Re: [Starpu-devel] support for cudaMemcpyPeer, Samuel Thibault, 24/03/2018
- Re: [Starpu-devel] support for cudaMemcpyPeer, Hatem Ltaief, 24/03/2018
- Re: [Starpu-devel] support for cudaMemcpyPeer, Samuel Thibault, 25/03/2018
- Re: [Starpu-devel] support for cudaMemcpyPeer, Hatem Ltaief, 25/03/2018
