Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] support for cudaMemcpyPeer
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] support for cudaMemcpyPeer
  • Date: Sun, 25 Mar 2018 10:58:22 +0000
  • Accept-language: en-GB, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=4622b27f9e=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On Mar 24, 2018, at 4:09 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hatem Ltaief, on sam. 24 mars 2018 13:52:01 +0000, wrote:
You are right, I have omitted the dyn libs. So, it is there
How is it there exactly?  Please send the nm output :)
hltaief@samsara:~/benchmarks/dpotrf$ nm -D /usr/local/cuda/lib64/libcudart.so.9.0 | grep MemcpyPeer
000000000003f510 T cudaMemcpyPeer
000000000004bdd0 T cudaMemcpyPeerAsync
There is no reason why we should use -lcudart_static.
That being said, I just dropped that detection, it can only pose problem
whenever NVidia does tricky things with the symbol, and nowadays we can
safely assume by default that it is available.
Not sure I followed you on this one.
Can you please explain?
Thanks
H
This message and its contents including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
