Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] support for cudaMemcpyPeer
Archives de la liste
Chronologique Discussions
  • To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] support for cudaMemcpyPeer
  • Date: Sun, 25 Mar 2018 13:02:50 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hatem Ltaief, on dim. 25 mars 2018 10:58:22 +0000, wrote:
> On Mar 24, 2018, at 4:09 PM, Samuel Thibault
> <[1]samuel.thibault@inria.fr>
> wrote:
> Hatem Ltaief, on sam. 24 mars 2018 13:52:01 +0000, wrote:
> You are right, I have omitted the dyn libs. So, it is there
> How is it there exactly? Please send the nm output :)
> hltaief@samsara:~/benchmarks/dpotrf$ nm -D /usr/local/cuda/lib64/
> libcudart.so.9.0 | grep MemcpyPeer
> 000000000003f510 T cudaMemcpyPeer
> 000000000004bdd0 T cudaMemcpyPeerAsync
Ok, so I have no idea why the test would fail to find it.
> There is no reason why we should use -lcudart_static.
> That being said, I just dropped that detection, it can only pose problem
> whenever NVidia does tricky things with the symbol, and nowadays we can
> safely assume by default that it is available.
> Not sure I followed you on this one.
> Can you please explain?
I simply removed the test, and instead made configure assume that the
symbol is there, which gets the issue away.
Samuel
Haut de le page
