Archives de la liste
Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems
Chronologique Discussions
- To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Cc: Kadir Akbudak <kadir.akbudak@kaust.edu.sa>, Aniello Esposito <esposito@cray.com>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Aleksandr Mikhalev <aleksandr.mikhalev@kaust.edu.sa>, "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems
- Date: Thu, 26 Apr 2018 17:16:11 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hatem Ltaief, le jeu. 26 avril 2018 15:13:57 +0000, a ecrit:
> > Hatem Ltaief, le jeu. 26 avril 2018 14:57:42 +0000, a ecrit:
> >> We reduced then the number of worker threads per node to 16 and 8: we
> >> recover
> >> our parallel efficiency up to a decent level!
> > But did it achieve the computation faster?
> YES
Ok. Which scheduler is it using?
It'd be good if we could reproduce it to be able to analyze what is
going on more precisely.
Samuel
- [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Hatem Ltaief, 26/04/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Samuel Thibault, 26/04/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Hatem Ltaief, 26/04/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Sameh Abdulah, 26/04/2018
