Archives de la liste
Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems
Chronologique Discussions
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: Kadir Akbudak <kadir.akbudak@kaust.edu.sa>, Aniello Esposito <esposito@cray.com>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Aleksandr Mikhalev <aleksandr.mikhalev@kaust.edu.sa>, "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems
- Date: Thu, 26 Apr 2018 15:38:02 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=5654d6edfa=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
The cced people can help but I believe this was eager scheduler
H
Sent from my iPhone
> On Apr 26, 2018, at 18:20, Samuel Thibault <samuel.thibault@inria.fr> wrote:
> Hatem Ltaief, le jeu. 26 avril 2018 15:13:57 +0000, a ecrit:
>>> Hatem Ltaief, le jeu. 26 avril 2018 14:57:42 +0000, a ecrit:
>>>> We reduced then the number of worker threads per node to 16 and 8: we
>>>> recover
>>>> our parallel efficiency up to a decent level!
>>> But did it achieve the computation faster?
>> YES
> Ok. Which scheduler is it using?
> It'd be good if we could reproduce it to be able to analyze what is
> going on more precisely.
> Samuel
________________________________
This message and its contents including attachments are intended solely for
the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete this
message from your computer system. Any unauthorized use or distribution is
prohibited. Please consider the environment before printing this email.
- [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Hatem Ltaief, 26/04/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Samuel Thibault, 26/04/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Hatem Ltaief, 26/04/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Sameh Abdulah, 26/04/2018
