Archives de la liste
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Cc: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Subject: [Starpu-devel] Passing a structure to starpu insert task
- Date: Tue, 1 May 2018 09:54:44 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=6659864b23=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear StarPU dev,
I am trying to pass a single data structure (composed of int, float, etc...)
to a starpu insert task API using STARPU_VALUE. Is that the right way to do
it for data structures?
Thanks
Hatem
Sent from my iPhone
________________________________
This message and its contents including attachments are intended solely for
the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete this
message from your computer system. Any unauthorized use or distribution is
prohibited. Please consider the environment before printing this email.
- [Starpu-devel] Passing a structure to starpu insert task, Hatem Ltaief, 01/05/2018
- Re: [Starpu-devel] Passing a structure to starpu insert task, Samuel Thibault, 01/05/2018
- Re: [Starpu-devel] Passing a structure to starpu insert task, Hatem Ltaief, 02/05/2018
