Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Passing a structure to starpu insert task
Archives de la liste
Chronologique Discussions
  • To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Passing a structure to starpu insert task
  • Date: Tue, 1 May 2018 11:56:11 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:tIbVbx2TOEUa7sPPsmDT+DRfVm0co7zxezQtwd8ZseISKvad9pjvdHbS+e9qxAeQG9mDsLQc06L/iOPJYSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQFcVGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q99pHPbQhEniaxba9vJxiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UKdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7Vq4/Vyi84Kh3SR/okCYHOCA/8GHLkcx7kaZXrAu8qxBj34LYZYeYP+d8cKzAZ9MXXWRPUMZPWSJcAY28YYQAAPYcMulaqInyqUADrQeiCQWwGO/j1iVFimHw0KYn0+ohCwbG3Ak4EtwTqnvUqcj1O7kWUeuo0qfIzTTDYOhM1jfg7IjIbg0qrPaXXb1qdMrR1FcgFwffglWMqYzlPiia2f4Qs2if8+ptTuOvi2g9qwFwuDej3MksipPQi48T11vK9j15zZ4oKdC7SEN3e8CoHZVeui2AKod6Xt8uT3t1tCoi17ELu5+2cDIXxJknxBPTceGLf5WV7h75SeqdPzF1j29/dr2lnRa9602gx/X8Vsaq1FZKqTJIktnSuXAXzRPf8NKISuJg/keg3TaAyQbT5f9YIUwum6rbMYYtwr82lpUNrUTOBjL6lUb2gaOMaEkp9Oal5/76brn6upOQLZJ4hhn7Mqs0m8y/Beo4MhIJX2ie4em8z6fs/UjkQLpUiv06iLXZsJDbJcsAvKG5HgtV0po45hmhCTemy80UnX0HLVJCfhKLlY/pO0vBIPzgF/ewn0yskCt3x/DBJrDhGYnNIWLZkLf5YLZx8lNTxxQtzd9B45JZEbUBIPPoWk/tr9zUFBA5MwKzw+b9B9VyyJkSWWOJAq+DMaPdq0WE5uw1I7rEWIhAmD/hJv1tw+LnjHI30QsddLWk2N0TdHm5E/pOIEyEemaqj9scV3wD6FkQVuvv3WaLVCNeYz6OX6M27yw/FMryFo7GW42pxqCB3S2yA5lKTmFAEFGFV3nyIdbXE8wQYT6fd5cy2gcPUqKsHsp4jUn35V3KjoF/J++RwRU28Jfq1dx7/erWzE1g+DpvSsCM1GfLSHt7zDlRG20GmZtnqEk48W+tlLBiiqUAR91V/fJAFAkgZ8aFkr5KTuvqUweERe+nDVarRtL/UGMxQ8g4hdYXfkd5FtOvklbNxXjzDg==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hatem Ltaief, le mar. 01 mai 2018 09:54:44 +0000, a ecrit:
> I am trying to pass a single data structure (composed of int, float,
> etc...) to a starpu insert task API using STARPU_VALUE. Is that the right
> way to do it for data structures?
You can pass both the pointer to the structure and the size of the
structure, yes.
Samuel
Haut de le page
