Archives de la liste
- From: Adrien Roussel <adrien.roussel@itwm.fraunhofer.de>
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Dépendances dynamiques
- Date: Tue, 12 Jun 2018 09:38:31 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=adrien.roussel@itwm.fraunhofer.de; spf=Pass smtp.mailfrom=adrien.roussel@itwm.fraunhofer.de; spf=None smtp.helo=postmaster@mail-edgeDD24.fraunhofer.de
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: Fraunhofer ITWM
Bonjour,
Merci beaucoup de vos réponses. J'ai une dernière petite question à vous poser.
J'aimerais pouvoir rendre une tâche persistante afin de pouvoir la rejouer à l'intérieur d'une boucle.
Pour cela, je construis une tâche "starpu_task", que j'initialise une fois seulement et que j'aimerais exécuter plusieurs fois grâce à la fonction "starpu_task_submit".
Sauf que, j'ai l'impression que StarPU libère la mémoire de ma tache après son exécution.
J'ai essayé de garder une tâche "persistante" que je n'exécute pas, et lors du passage dans ma boucle de faire un memcpy dans une tâche temporaire et d'exécuter celle-ci.
Mais visiblement quelque chose se brise quand même car j'ai une erreur de segmentation dans ce cas là.
Existe-t-il de rendre une tâche persistante ? Ou dois-je reconstruire ma tâche à chaque itération ?
Merci beaucoup
On 06/11/2018 02:32 PM, Samuel Thibault wrote:
Adrien Roussel, le lun. 11 juin 2018 14:25:51 +0200, a ecrit:
Si je comprends bien, dans mon codelet je n'ai qu'à spécifierOui.
STARPU_VARIABLE_NBUFFERS au lieu du nombre de dépendances.
Est-ce que je dois le spécifier dans la tâche ou dans le codelet ? Ou lesDans la codelet seulement, c'est du coup dans la tâche qu'il faudra
deux ?
spécifier combien il y en a finalement.
Ensuite, selon le nombre d'argument que j'ai, je peux enregistrer à la voléeOui.
toutes mes variables ainsi que leur mode ?
Est-ce qu'il y aurait un exemple de cette partie ?grep -r VARIABLE tests examples
en montre beaucoup :)
Samuel
| Dr. Adrien Roussel
| Competence Center High Performance Computing
| Fraunhofer Institut ITWM
| Tel. : +49 631 31600-4984
| E-Mail : adrien.roussel@itwm.fraunhofer.de
| Web : https://adrien-roussel.eu
| Address: Fraunhofer-Platz 1
| D-67663 Kaiserslautern
- [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 11/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 11/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 11/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 12/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 12/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 14/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 14/06/2018
- Message indisponible
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 29/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 29/06/2018
