Archives de la liste
- From: Adrien Roussel <adrien.roussel@itwm.fraunhofer.de>
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Dépendances dynamiques
- Date: Thu, 14 Jun 2018 15:24:41 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=adrien.roussel@itwm.fraunhofer.de; spf=Pass smtp.mailfrom=adrien.roussel@itwm.fraunhofer.de; spf=None smtp.helo=postmaster@mail-edgeKA24.fraunhofer.de
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: Fraunhofer ITWM
Bonjour,
Désolé de déranger à nouveau, mais j'essaye de me faire la main sur une réduction toute simple, sauf que j'ai des problèmes de data race.
J'essaye de faire une réduction d'un vecteur m_x, de taille m_size dans une variable m_res.
J'ai suivi les exemples donnés dans la doc StarPU, mais pourtant j'ai l'impression que les dépendances ne sont pas prises en compte.
Dans un premier temps, dans le constructeur je donne dépendances en entrée dans un tableau de "struct starpu_data_descr" nommé "x_descr".
Que je passerais ensuite en argument lors de l'insertion de la tâche, en plus de la variable d'accumulation.
Est-ce que par tout hasard j'aurais négligé quelque chose lors du développement ?
Merci d'avance.
Voici ma classe :
template<typename ValueType>
class StarPU_reduction : public StarPUBlas
typedef StarPUBlas BaseType;
public:
StarPU_reduction (int _dom, ValueType* _x,
ValueType* _res, int _size)
: m_res (_res), BaseType (_dom), m_x(_x), m_size(_size)
#ifdef USE_STARPU
// Registration of the data
m_x_handle = (starpu_data_handle_t*) malloc(sizeof(starpu_data_handle_t) * m_size);
x_descr = (starpu_data_descr*) malloc(sizeof(starpu_data_descr) * m_size);
for(int i = 0; i < m_size; ++i)
starpu_variable_data_register(&m_x_handle[i], STARPU_MAIN_RAM, (uintptr_t)&m_x[i], sizeof(m_x[i]));
x_descr[i] = {};
x_descr[i].handle = m_x_handle[i];
x_descr[i].mode = STARPU_R;
starpu_variable_data_register(&m_res_handle, STARPU_MAIN_RAM, (uintptr_t)m_res, sizeof(m_res[0]));
// Configuration of the codelet
cl = {};
cl.cpu_funcs[0] = cpu_reduction;
cl.nbuffers = STARPU_VARIABLE_NBUFFERS;
#endif
void
exec ()
#ifdef USE_STARPU
int ret = starpu_task_insert(&cl, STARPU_W, m_res_handle, STARPU_DATA_MODE_ARRAY, x_descr, m_size, 0);
#else
cpu_reduction( m_x, m_res, m_size);
#endif
void print()
std::cout << "PART: " << m_dom_id << "\tREDUCTION" << std::endl;
private:
ValueType* m_x;
ValueType* m_res;
int m_size;
#ifdef USE_STARPU
struct vec_size_t params;
struct starpu_codelet cl;
struct starpu_task *task;
struct starpu_data_descr* x_descr;
starpu_data_handle_t* m_x_handle;
starpu_data_handle_t m_res_handle;
#endif
On 06/12/2018 09:46 AM, Samuel Thibault wrote:
Adrien Roussel, le mar. 12 juin 2018 09:38:31 +0200, a ecrit:
Sauf que, j'ai l'impression que StarPU libère la mémoire de ma tache aprèsOui, c'est le champ destroy, que tu peux mettre à 0 pour éviter qu'il le
son exécution.
fasse.
Samuel
| Dr. Adrien Roussel
| Competence Center High Performance Computing
| Fraunhofer Institut ITWM
| Tel. : +49 631 31600-4984
| E-Mail : adrien.roussel@itwm.fraunhofer.de
| Web : https://adrien-roussel.eu
| Address: Fraunhofer-Platz 1
| D-67663 Kaiserslautern
- [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 11/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 11/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 11/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 12/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 12/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 14/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 14/06/2018
- Message indisponible
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 29/06/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 29/06/2018
