Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Dépendances dynamiques
Archives de la liste
Chronologique Discussions
  • To: Adrien Roussel <adrien.roussel@itwm.fraunhofer.de>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Dépendances dynamiques
  • Date: Thu, 14 Jun 2018 16:38:07 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Bonjour,
Adrien Roussel, le jeu. 14 juin 2018 15:24:41 +0200, a ecrit:
>   Désolé de déranger à nouveau, mais j'essaye de me faire la main sur une
> réduction toute simple, sauf que j'ai des problèmes de data race.
C'est-à-dire ? Quel est le symptôme ?
> J'essaye de faire une réduction d'un vecteur m_x, de taille m_size dans une
> variable m_res.
> J'ai suivi les exemples donnés dans la doc StarPU, mais pourtant j'ai
> l'impression que les dépendances ne sont pas prises en compte.
Qu'est-ce qui te fait penser cela ?
> Dans un premier temps, dans le constructeur je donne dépendances en entrée
> dans un tableau de "struct starpu_data_descr" nommé "x_descr".
> Que je passerais ensuite en argument lors de l'insertion de la tâche, en
> plus de la variable d'accumulation.
> Est-ce que par tout hasard j'aurais négligé quelque chose lors du
> développement ?
Ça a l'air correct, il faudrait aussi voir le code de la fonction
cpu_reduction, elle ne peut pas être simplement cpu_reduction(float *,
float *, size_t);, cf les exemples, c'est toujours void func_name(void
*buffers[], void *cl_arg) (mais normalement le compilateur devrait
soulever un warning si ce n'est pas le cas).
Samuel
Haut de le page
