Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS
Archives de la liste
Chronologique Discussions
  • To: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS
  • Date: Fri, 05 Oct 2018 10:02:42 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
Is there a way to set the data target node when starpu_codelet::nbuffers is set to STARPU_VARIABLE_NBUFFERS
Best Regards,
Mirko Myllykoski
Haut de le page
