Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [StarPU+MPI debuging]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [StarPU+MPI debuging]
  • Date: Fri, 5 Oct 2018 12:18:03 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-qk1-f175.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear all,
I experience the following StarpU+MPI problem. The code either hangs or crashes with the following debug backtrace. I'm not very certain, if there is anything else I could do to analyse the problem further. I run the code via mpiexec -np 1 gdb ./test. Thank you and have a good day ahead!
Thread 2 "CPU 0" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffed0e4700 (LWP 4121)]
0x00007ffff7b72e92 in _starpu_can_use_nth_implementation (nimpl=0,
    cl=0x82fff7e99e20, arch=STARPU_CPU_WORKER) at core/workers.c:283
283                     return func != NULL;
(gdb) bt
#0  0x00007ffff7b72e92 in _starpu_can_use_nth_implementation (nimpl=0,
#1  starpu_worker_can_execute_task (workerid=workerid@entry=0,
    task=task@entry=0x555555889890, nimpl=nimpl@entry=0) at core/workers.c:334
#2  0x00007ffff7c23d6b in pred_can_execute (pworkerid=<optimized out>,
    t=<optimized out>) at sched_policies/prio_deque.c:36
#3  _starpu_prio_deque_pop_task_for_worker (pdeque=0x555555882cd0,
    workerid=workerid@entry=0, skipped=skipped@entry=0x7fffed0e32e4)
    at sched_policies/prio_deque.c:71
#4  0x00007ffff7bb79dd in ws_pick_task (ws=0x55555587fbd0, target=0, source=0)
    at sched_policies/work_stealing_policy.c:541
#5  ws_pop_task (sched_ctx_id=0) at sched_policies/work_stealing_policy.c:541
#6  0x00007ffff7ba0a25 in _starpu_pop_task (
    worker=worker@entry=0x7ffff7c89500 <_starpu_config+1568>)
    at core/sched_policy.c:869
#7  0x00007ffff7bcc352 in _starpu_get_worker_task (
    worker=worker@entry=0x7ffff7c89500 <_starpu_config+1568>,
    workerid=workerid@entry=0, memnode=memnode@entry=0)
    at drivers/driver_common/driver_common.c:375
#8  0x00007ffff7c36236 in _starpu_cpu_driver_run_once (
    cpu_worker=cpu_worker@entry=0x7ffff7c89500 <_starpu_config+1568>)
    at drivers/cpu/driver_cpu.c:303
#9  0x00007ffff7c364ed in _starpu_cpu_worker (
    arg=0x7ffff7c89500 <_starpu_config+1568>) at drivers/cpu/driver_cpu.c:407
#10 0x00007ffff1aa1a9d in start_thread () from /usr/lib/libpthread.so.0
#11 0x00007ffff19d1a43 in clone () from /usr/lib/libc.so.6
Best wishes,
Maxim
  • [Starpu-devel] [StarPU+MPI debuging], Maxim Abalenkov, 05/10/2018
Haut de le page
