Archives de la liste
- To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Fri, 18 Jan 2019 09:21:34 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Amani Alonazi, le ven. 18 janv. 2019 11:15:35 +0300, a ecrit:
> yes:
> cudaMemcpy(dest, src,
> x*y*sizeof(float),
> cudaMemcpyDeviceToDevice);
For these, you can use cudaMemcpyAsync.
Otherwise, each of these calls will introduce a synchronization barrier
with all other GPU operations.
Samuel
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, (suite)
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 18/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 18/01/2019
