Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Fri, 18 Jan 2019 10:26:49 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f47.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
All kernels except memecpy are using the asynchronous CUDA submission, i.e., :
cudaStream_t stream = starpu_cuda_get_local_stream();
KERNEL<<<..., stream >>>();
#ifndef STARPU_CUDA_ASYNC
cudaStreamSynchronize( stream );
#endif
#endif
I'll reinstall and update starpu to 1.3 branch.
Many thanks!
On Thu, Jan 17, 2019 at 7:47 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
About the missing overlapping of transfers and CUDA computation, I'm
realizing that in StarPU 1.2.x that wasn't indeed as well supported as
it is now, you may want to try the starpu-1.3 branch, which I have btw
fixed to avoid making GPU workers care about disk operations.
Samuel
Amani
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, (suite)
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 18/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 18/01/2019
