Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
  • Date: Fri, 18 Jan 2019 11:22:28 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f52.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
yes, it does set the STARPU_CUDA_ASYNC flags in the codelet:
#ifdef STARPU_CUDA_ASYNC
#define CODELET_CUDA_FLAGS(flags) .cuda_flags = {(flags)},
I also was wondering if it's actually defined I added a compile-time-buggy text in the phrase below but it compiles. In theory, at least 10 executives computations shall appear concurrent with the desk write.
#ifndef STARPU_CUDA_ASYNC
  error here * 10^6
  cudaStreamSynchronize( stream );
#endif
On Fri, Jan 18, 2019 at 11:15 AM Amani Alonazi <amani.alonazi@kaust.edu.sa> wrote:
yes:
cudaMemcpy(dest, src,
           x*y*sizeof(float),
           cudaMemcpyDeviceToDevice);
On Fri, Jan 18, 2019 at 11:08 AM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Amani Alonazi, le ven. 18 janv. 2019 10:26:49 +0300, a ecrit:
> All kernels except memecpy are using the asynchronous CUDA submission,
By memcpy, I guess you mean a cpu-only memcpy?
Samuel
Amani AlOnazi
PhD Student
Extreme Computing Research Center
King Abdullah University of Science and Technology
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS02
Telephone: +966 (12) 808 0218
Mobile: +966 (0) 555191795
Email: amani.alonazi@kaust.edu.sa
www.kaust.edu.sa
Amani AlOnazi
PhD Student
www.kaust.edu.sa
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
