Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Data movement per kernel
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, <starpu-devel@lists.gforge.inria.fr>
  • Cc: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Data movement per kernel
  • Date: Wed, 20 Feb 2019 09:55:06 +0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sameh.abdulah@kaust.edu.sa; spf=Pass smtp.mailfrom=sameh.abdulah@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f53.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Team,
We are working on a mixed precision project which mainly relies on the Cholesky factorization operation. We are facing a large data movement on distributed systems which we have realized using STARPU_COMM_STATS.
My question is: Is there any way to estimate the data movement cost per kernel? STARPU_COMM_STATS estimates the data movement cost per computing node which helped us to investigate the problem but not to understand the reason behind it.
Thanks,
--Sameh Abdulah
Postdoctoral Fellow,
Extreme Computing Research Center (ECRC),
King Abdullah University of Science and Technology (KAUST).
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
