Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Data movement per kernel
- Date: Wed, 27 Feb 2019 15:58:28 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sameh.abdulah@kaust.edu.sa; spf=Pass smtp.mailfrom=sameh.abdulah@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f46.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
https://www.safaribooksonline.com/library/view/mastering-parallel-programming/9781784394004/ch04s02.html
On 2/26/19, 6:25 PM, "Samuel Thibault" <samuel.thibault@inria.fr> wrote:
Hello,
Sameh Abdulah, le mer. 20 févr. 2019 09:55:06 +0300, a ecrit:
> My question is: Is there any way to estimate the data movement cost per
kernel?
> STARPU_COMM_STATS estimates the data movement cost per computing node
which
> helped us to investigate the problem but not to understand the reason
behind
> it.
Mmm, there currently isn't.
We could implement this inside starpu-mpi by accounting the movements
within the codelet structure, and let you access the information from
there.
Samuel
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
- Re: [Starpu-devel] Data movement per kernel, Sameh Abdulah, 20/02/2019
- Re: [Starpu-devel] Data movement per kernel, Samuel Thibault, 26/02/2019
- Re: [Starpu-devel] Data movement per kernel, Sameh Abdulah, 27/02/2019
