Archives de la liste
Re: [Starpu-devel] environment variable for instrumenting the write back to disk
Chronologique Discussions
- To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] environment variable for instrumenting the write back to disk
- Date: Wed, 13 Mar 2019 12:41:58 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Amani Alonazi, le mer. 13 mars 2019 14:16:48 +0300, a ecrit:
> Is there already built script to visualize the content of tasks.rec?
Well, there is a lot of information in there, so there is no simple
answer to this, so we have not build any particular script. Usually
people just grep out what they need.
> One more thing, is it possible to change the location of starpu home folder
> which usually contains the sampling?
Yes, see the environment variable section of the documentation:
STARPU_HOME, but also STARPU_PERF_MODEL_DIR.
Samuel
- [Starpu-devel] environment variable for instrumenting the write back to disk, Hatem Ltaief, 12/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Samuel Thibault, 12/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Amani Alonazi, 12/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Amani Alonazi, 13/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Samuel Thibault, 13/03/2019
