Archives de la liste
Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Emmanuel Agullo <Emmanuel.Agullo@inria.fr>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Florent Pruvost <florent.pruvost@inria.fr>, Ludovic Courtès <ludovic.courtes@inria.fr>
- Subject: Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school
- Date: Wed, 23 Oct 2019 12:00:18 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Manu,
Could you please send me the
environment i need to call guix ?
Here what i get.
[hpcs-furment@miriel001 ~]$ guix build
starpu --no-grafts --check
guix build: erreur : starpu : paquet inconnu [hpcs-furment@miriel001 ~]$ Thanks!
Nathalie
On 22/10/2019 21:25, Emmanuel Agullo
wrote:
Dear StarPU team, I succeed to build starpu with guix on: - my laptop, - plafrim frontal node (devel13), - a computing node on plafrim of type miriel (miriel015). To do that, on any of those machines I run: guix build starpu --no-grafts --check And it's all working great. However, when I am trying to build it on the plafrim-hpcs machine (the partition of plafrim that we'll use for the HPC school in November), I obtain an error during the starpu check step. I get that both on the frontal node of plafrim-hpcs (mistral01) and on a compute node (miriel001). The failure is related to starpu_machine_display: FAIL: starpu_machine_display ============================ [starpu][check_bus_config_file] No performance model for the bus, calibrating... [starpu][check_bus_config_file] ... done [error] `./starpu_machine_display' killed with signal 11; test marked as failed warning: core file may not match specified executable file. [New LWP 24848] [Thread debugging using libthread_db enabled] Using host libthread_db library "/gnu/store/ahqgl4h89xqj695lgqvsaf6zh2nhy4pj-glibc-2.29/lib/libthread_db.so.1". Core was generated by `/tmp/guix-build-starpu-1.3.2.drv-0/source/tools/.libs/starpu_machine_display'. Program terminated with signal SIGSEGV, Segmentation fault. #0 starpu_tree_get_neighbour (tree=tree@entry=0x41d400, node=node@entry=0x41d400, visited=visited@entry=0x7fffffffc5e8 "\001", present=present@entry=0x41d594 "\001") at core/tree.c:113 113 for(st = 0; st < father->arity; st++)
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux |
- [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 22/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Nathalie Furmento, 23/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 23/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 24/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Nathalie Furmento, 25/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 25/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Ludovic Courtès, 25/10/2019
