Archives de la liste
Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school
Chronologique Discussions
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Ludovic Courtès <ludovic.courtes@inria.fr>
- Subject: Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school
- Date: Fri, 25 Oct 2019 15:12:53 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear Nathalie, dear all,
Thanks very much once again for the great and accurate support!
Best,
Manu
Nathalie Furmento <nathalie.furmento@labri.fr> writes:
> Hello,
> The problem has been fixed. Thanks a lot to Manu for finding out the
> problem, and to Ludo and Brice for your help in wizarding StarPU's code.
> However, it's still not possible to fully run StarPU on a single-core
> machine without a /sys directory. We will keep investigating that problem.
> In the meantime, i could run
> guix build starpu
> on the PlaFRIM training machine (with a slightly degraded check
> process), and the package starpu@1.3 is ready to be used.
> Cheers,
> Nathalie
> On 24/10/2019 19:50, Emmanuel Agullo wrote:
>> Dear Nathalie,
>> Thanks much for having fixed the issue (due to the fact that guix was
>> building starpu on a virtual machine with a single core available
>> and that that case was not tested, if I understood correctly the
>> results of your investigations), for the new relase (1.3.3) of StarPU
>> and for its integration in guix-hpc!
>> https://gitlab.inria.fr/guix-hpc/guix-hpc/commit/6554347b87c43640d769bc4bc80bec6688b79c3f
>> Yet, the build seems to have a remaining issue, and the log (extraction
>> below) seems to be related once again to the fact that there is only
>> one CPU core available (hence ... no workers) in the build environment.
>> Once again, thanks very much for the great support.
>> With best regards,
>> Manu
>> Testsuite summary for StarPU 1.3.3
>> # TOTAL: 214
>> # PASS: 156
>> # SKIP: 56
>> # XFAIL: 1
>> # FAIL: 1
>> # XPASS: 0
>> # ERROR: 0
>> See tests/test-suite.log
>> Please report to starpu-devel@lists.gforge.inria.fr
>> make[5]: *** [Makefile:9002: test-suite.log] Error 1
>> make[5]: Leaving directory
>> '/tmp/guix-build-starpu-1.3.3.drv-0/source/tests'
>> make[4]: *** [Makefile:9110: check-TESTS] Error 2
>> make[4]: Leaving directory
>> make[3]: *** [Makefile:10791: check-am] Error 2
>> make[3]: Leaving directory
>> make[2]: *** [Makefile:8894: check-recursive] Error 1
>> make[2]: Leaving directory
>> make[1]: *** [Makefile:10793: check] Error 2
>> make[1]: Leaving directory
>> make: *** [Makefile:833: check-recursive] Error 1
>> Test suite failed, dumping logs.
>> --- ./tests/test-suite.log
>> StarPU 1.3.3: tests/test-suite.log
>> # TOTAL: 214
>> # PASS: 156
>> # SKIP: 56
>> # XFAIL: 1
>> # FAIL: 1
>> # XPASS: 0
>> # ERROR: 0
>> .. contents:: :depth: 2
>> SKIP: main/bind
>> #Execution_time_in_seconds 0.033840 ./main/bind
>> SKIP main/bind (exit status: 77)
>> FAIL: main/starpu_worker_exists
>> failure with can_always_execute
>> #Execution_time_in_seconds 0.034313 ./main/starpu_worker_exists
>> `./main/starpu_worker_exists' exited with return code 1
>> FAIL main/starpu_worker_exists (exit status: 1)
>> SKIP: datawizard/readonly
>> copy 0
>> [starpu][_starpu_task_insert_v] submission of task 0x419ca0 with codelet
>> 0x4040c0 failed (symbol `none') (err: ENODEV)
>> WARNING: No one can execute this task
>> #Execution_time_in_seconds 0.033982 ./datawizard/readonly
>> SKIP datawizard/readonly (exit status: 77)
>> SKIP: datawizard/invalidate_pending_requests
>> #Execution_time_in_seconds 0.032424
>> ./datawizard/invalidate_pending_requests
>> SKIP datawizard/invalidate_pending_requests (exit status: 77)
>> XFAIL: errorcheck/invalid_blocking_calls
>> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(starpu_data_acquire_on_node+0x565)[0x7ffff7f0b255]
>> /tmp/guix-build-starpu-1.3.3.drv-0/source/tests/errorcheck/.libs/invalid_blocking_calls[0x401685]
>> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(+0xdf03c)[0x7ffff7f4203c]
>> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(_starpu_cpu_driver_run_once+0x164)[0x7ffff7f42574]
>> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(_starpu_cpu_worker+0x2d)[0x7ffff7f4271d]
>> /gnu/store/ahqgl4h89xqj695lgqvsaf6zh2nhy4pj-glibc-2.29/lib/libpthread.so.0(+0x8015)[0x7ffff7afa015]
>> /gnu/store/ahqgl4h89xqj695lgqvsaf6zh2nhy4pj-glibc-2.29/lib/libc.so.6(clone+0x3f)[0x7ffff7a1091f]
>> [starpu][starpu_data_acquire_on_node][assert failure] Acquiring a data
>> synchronously is not possible from a codelet or from a task callback, use
>> starpu_data_acquire_cb instead.
>> invalid_blocking_calls: datawizard/user_interactions.c:334:
>> starpu_data_acquire_on_node: Assertion
>> `_starpu_worker_may_perform_blocking_calls()' failed.
>> [error] `./errorcheck/invalid_blocking_calls' killed with signal 6; test
>> marked as failed
>> while looking for core file of ./errorcheck/invalid_blocking_calls:
>> core.32549: No such file or directory
>> while looking for core file of ./errorcheck/invalid_blocking_calls: core:
>> #Execution_time_in_seconds 0.107065 ./errorcheck/invalid_blocking_calls
>> XFAIL errorcheck/invalid_blocking_calls (exit status: 1)
>> SKIP: overlap/gpu_concurrency
>> --- ./tools/test-suite.log
>> StarPU 1.3.3: tools/test-suite.log
>> # TOTAL: 4
>> # PASS: 4
>> # SKIP: 0
>> # XFAIL: 0
>> # FAIL: 0
>> # XPASS: 0
>> # ERROR: 0
>> command "make" "check" failed with status 2
>> builder for `/gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv'
>> failed with exit code 1
>> la compilation de
>> /gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv a échoué
>> Aucun journal de compilation pour «
>> /gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv ».
>> guix build: erreur : build of
>> `/gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv' failed
>> In case it may be useful, here is the channels.scm used for this "guix
>> build starpu" test.
>> [hpcs-agullo@miriel001 hou10ni_school_2019]$ guix describe
>> --format=channels
>> (list (channel
>> (name 'guix-hpc)
>> (url "https://gitlab.inria.fr/guix-hpc/guix-hpc.git")
>> (commit
>> "c70ab156deef43e8e9a09947ab15b0e1cc579b29"))
>> (channel
>> (name 'guix-hpc-non-free)
>> (url "https://gitlab.inria.fr/guix-hpc/guix-hpc-non-free.git")
>> (commit
>> "0822b7eebb63e2360125e017934ba817686d9669"))
>> (channel
>> (name 'guix)
>> (url "https://git.savannah.gnu.org/git/guix.git")
>> (commit
>> "bfaa06171842225c8bf4c839e35ac36a0b2c2d59")))
>> Emmanuel Agullo <Emmanuel.Agullo@inria.fr> writes:
>>> Dear Nathalie,
>>> Thanks much for considering this issue.
>>> Yes, it's here:
>>>> eagullo@tek9:/tmp/toto$ guix describe --format=channels
>>>> (list (channel
>>>> (commit
>>>> (channel
>>>> (name 'guix-hpc)
>>>> (commit
>>>> "b24a8fa55bfd4a0987320e0e45d3a85f0920427c"))
>>>> (channel
>>>> (name 'guix)
>>>> (commit
>>> Just need to copy and paste it on ~/.config/guix/channels.scm
>>> and "guix pull".
>>> And then the "guix build starpu" should be available.
>>> Thanks once again!
>>> Best,
>>> Manu
- [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 22/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Nathalie Furmento, 23/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 23/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 24/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Nathalie Furmento, 25/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Emmanuel Agullo, 25/10/2019
- Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school, Ludovic Courtès, 25/10/2019
