Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Emmanuel Agullo <Emmanuel.Agullo@inria.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Ludovic Courtès <ludovic.courtes@inria.fr>
  • Subject: Re: [Starpu-devel] starpu / guix on plafrim partition dedicated for the November HPC school
  • Date: Fri, 25 Oct 2019 14:53:32 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
The problem has been fixed. Thanks a lot to Manu for finding out the
problem, and to Ludo and Brice for your help in wizarding StarPU's code.
However, it's still not possible to fully run StarPU on a single-core
machine without a /sys directory. We will keep investigating that problem.
In the meantime, i could run
guix build starpu
on the PlaFRIM training machine (with a slightly degraded check
process), and the package starpu@1.3 is ready to be used.
Cheers,
Nathalie
On 24/10/2019 19:50, Emmanuel Agullo wrote:
> Dear Nathalie,
> Thanks much for having fixed the issue (due to the fact that guix was
> building starpu on a virtual machine with a single core available
> and that that case was not tested, if I understood correctly the
> results of your investigations), for the new relase (1.3.3) of StarPU
> and for its integration in guix-hpc!
> https://gitlab.inria.fr/guix-hpc/guix-hpc/commit/6554347b87c43640d769bc4bc80bec6688b79c3f
> Yet, the build seems to have a remaining issue, and the log (extraction
> below) seems to be related once again to the fact that there is only
> one CPU core available (hence ... no workers) in the build environment.
> Once again, thanks very much for the great support.
> With best regards,
> Manu
> Testsuite summary for StarPU 1.3.3
> # TOTAL: 214
> # PASS: 156
> # SKIP: 56
> # XFAIL: 1
> # FAIL: 1
> # XPASS: 0
> # ERROR: 0
> See tests/test-suite.log
> Please report to starpu-devel@lists.gforge.inria.fr
> make[5]: *** [Makefile:9002: test-suite.log] Error 1
> make[5]: Leaving directory '/tmp/guix-build-starpu-1.3.3.drv-0/source/tests'
> make[4]: *** [Makefile:9110: check-TESTS] Error 2
> make[4]: Leaving directory '/tmp/guix-build-starpu-1.3.3.drv-0/source/tests'
> make[3]: *** [Makefile:10791: check-am] Error 2
> make[3]: Leaving directory '/tmp/guix-build-starpu-1.3.3.drv-0/source/tests'
> make[2]: *** [Makefile:8894: check-recursive] Error 1
> make[2]: Leaving directory '/tmp/guix-build-starpu-1.3.3.drv-0/source/tests'
> make[1]: *** [Makefile:10793: check] Error 2
> make[1]: Leaving directory '/tmp/guix-build-starpu-1.3.3.drv-0/source/tests'
> make: *** [Makefile:833: check-recursive] Error 1
> Test suite failed, dumping logs.
> --- ./tests/test-suite.log
> StarPU 1.3.3: tests/test-suite.log
> # TOTAL: 214
> # PASS: 156
> # SKIP: 56
> # XFAIL: 1
> # FAIL: 1
> # XPASS: 0
> # ERROR: 0
> .. contents:: :depth: 2
> SKIP: main/bind
> #Execution_time_in_seconds 0.033840 ./main/bind
> SKIP main/bind (exit status: 77)
> FAIL: main/starpu_worker_exists
> failure with can_always_execute
> #Execution_time_in_seconds 0.034313 ./main/starpu_worker_exists
> `./main/starpu_worker_exists' exited with return code 1
> FAIL main/starpu_worker_exists (exit status: 1)
> SKIP: datawizard/readonly
> copy 0
> [starpu][_starpu_task_insert_v] submission of task 0x419ca0 with codelet
> 0x4040c0 failed (symbol `none') (err: ENODEV)
> WARNING: No one can execute this task
> #Execution_time_in_seconds 0.033982 ./datawizard/readonly
> SKIP datawizard/readonly (exit status: 77)
> SKIP: datawizard/invalidate_pending_requests
> #Execution_time_in_seconds 0.032424 ./datawizard/invalidate_pending_requests
> SKIP datawizard/invalidate_pending_requests (exit status: 77)
> XFAIL: errorcheck/invalid_blocking_calls
> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(starpu_data_acquire_on_node+0x565)[0x7ffff7f0b255]
> /tmp/guix-build-starpu-1.3.3.drv-0/source/tests/errorcheck/.libs/invalid_blocking_calls[0x401685]
> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(+0xdf03c)[0x7ffff7f4203c]
> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(_starpu_cpu_driver_run_once+0x164)[0x7ffff7f42574]
> /tmp/guix-build-starpu-1.3.3.drv-0/source/src/.libs/libstarpu-1.3.so.2(_starpu_cpu_worker+0x2d)[0x7ffff7f4271d]
> /gnu/store/ahqgl4h89xqj695lgqvsaf6zh2nhy4pj-glibc-2.29/lib/libpthread.so.0(+0x8015)[0x7ffff7afa015]
> /gnu/store/ahqgl4h89xqj695lgqvsaf6zh2nhy4pj-glibc-2.29/lib/libc.so.6(clone+0x3f)[0x7ffff7a1091f]
> [starpu][starpu_data_acquire_on_node][assert failure] Acquiring a data
> synchronously is not possible from a codelet or from a task callback, use
> starpu_data_acquire_cb instead.
> invalid_blocking_calls: datawizard/user_interactions.c:334:
> starpu_data_acquire_on_node: Assertion
> `_starpu_worker_may_perform_blocking_calls()' failed.
> [error] `./errorcheck/invalid_blocking_calls' killed with signal 6; test
> marked as failed
> while looking for core file of ./errorcheck/invalid_blocking_calls:
> core.32549: No such file or directory
> while looking for core file of ./errorcheck/invalid_blocking_calls: core:
> #Execution_time_in_seconds 0.107065 ./errorcheck/invalid_blocking_calls
> XFAIL errorcheck/invalid_blocking_calls (exit status: 1)
> SKIP: overlap/gpu_concurrency
> --- ./tools/test-suite.log
> StarPU 1.3.3: tools/test-suite.log
> # TOTAL: 4
> # PASS: 4
> # SKIP: 0
> # XFAIL: 0
> # FAIL: 0
> # XPASS: 0
> # ERROR: 0
> command "make" "check" failed with status 2
> builder for `/gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv'
> failed with exit code 1
> la compilation de
> /gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv a échoué
> Aucun journal de compilation pour «
> /gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv ».
> guix build: erreur : build of
> `/gnu/store/75lm27wdcm9dwrjxabiiyi3ha4cfrgl4-starpu-1.3.3.drv' failed
> In case it may be useful, here is the channels.scm used for this "guix
> build starpu" test.
> [hpcs-agullo@miriel001 hou10ni_school_2019]$ guix describe --format=channels
> (list (channel
> (name 'guix-hpc)
> (url "https://gitlab.inria.fr/guix-hpc/guix-hpc.git";)
> (commit
> "c70ab156deef43e8e9a09947ab15b0e1cc579b29"))
> (channel
> (name 'guix-hpc-non-free)
> (url "https://gitlab.inria.fr/guix-hpc/guix-hpc-non-free.git";)
> (commit
> "0822b7eebb63e2360125e017934ba817686d9669"))
> (channel
> (name 'guix)
> (url "https://git.savannah.gnu.org/git/guix.git";)
> (commit
> "bfaa06171842225c8bf4c839e35ac36a0b2c2d59")))
> Emmanuel Agullo <Emmanuel.Agullo@inria.fr> writes:
>> Dear Nathalie,
>> Thanks much for considering this issue.
>> Yes, it's here:
>>> eagullo@tek9:/tmp/toto$ guix describe --format=channels
>>> (list (channel
>>> (commit
>>> (channel
>>> (name 'guix-hpc)
>>> (commit
>>> "b24a8fa55bfd4a0987320e0e45d3a85f0920427c"))
>>> (channel
>>> (name 'guix)
>>> (commit
>> Just need to copy and paste it on ~/.config/guix/channels.scm
>> and "guix pull".
>> And then the "guix build starpu" should be available.
>> Thanks once again!
>> Best,
>> Manu
Dr Nathalie Furmento Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
Haut de le page
