Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Rabab Al-omairy <rabab.omairy@kaust.edu.sa>, starpu-devel@lists.gforge.inria.fr, "hatem.ltaief" <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] StarPU changeable sizes and StarPU purge
- Date: Sun, 12 Jan 2020 14:16:25 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=rabab.omairy@kaust.edu.sa; spf=Pass smtp.mailfrom=rabab.omairy@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-pj1-f41.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear Samuel,
Your answer is really appreciated.
On Thu, Jan 9, 2020 at 8:51 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hello,
Rabab Al-omairy, le dim. 01 déc. 2019 22:03:43 +0300, a ecrit:
> after matrix compression each tile ends up having different sizes.
> However, on distributed memory on which tiles are 2D cyclically
> distributed among mpi nodes I have the following error:
> [1][starpu_mpi][_starpu_mpi_test_detached_requests][assert failure] MPI_Test
> returning MPI_ERR_TRUNCATE: message truncated
Mmm, indeed, the distributed support for matrices was not extended to
support tiles with varying size. Here the receiver is expecting a full
size since it doesn't know the size is smaller.
I have added some experimental support in the master. In order to try it
you need to uncomment the //#define DYNAMIC_MATRICES in both
src/datawizard/interfaces/matrix_interface.c and mpi/src/starpu_mpi_datatype.c
That is however for now incompatible with OOC support with O_DIRECT
enabled.
I will try your suggestion and let you know.
> For some matrix size which I can say matrix with medium size, I
> have the following message which cause application to stuck and not continue
> execution.
> [starpu][starpu_memchunk_tidy] Low memory left on node RAM 0 (6405MiB over
> 128808MiB).
So StarPU is lacking memory. Do you have OOC enabled?
I am not enabling OOC.
Samuel
Best Regards,
Rabab Alomairy
PhD Student
King Abdullah University of Science and Technology
Kingdom of Saudi Arabia
Extreme Computing Research Center
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS06
Mobile KSA: +966 (0) 548884792
E-mail: rabab.omairy@kaust.edu.sa
- Re: [Starpu-devel] StarPU changeable sizes and StarPU purge, Samuel Thibault, 09/01/2020
- Re: [Starpu-devel] StarPU changeable sizes and StarPU purge, Rabab Al-omairy, 12/01/2020
- Re: [Starpu-devel] StarPU changeable sizes and StarPU purge, Samuel Thibault, 12/01/2020
