Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU changeable sizes and StarPU purge
Archives de la liste
Chronologique Discussions
  • To: Rabab Al-omairy <rabab.omairy@kaust.edu.sa>
  • Cc: starpu-devel@lists.gforge.inria.fr, "hatem.ltaief" <Hatem.Ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] StarPU changeable sizes and StarPU purge
  • Date: Sun, 12 Jan 2020 12:50:29 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Rabab Al-omairy, le dim. 12 janv. 2020 14:16:25 +0300, a ecrit:
> On Thu, Jan 9, 2020 at 8:51 PM Samuel Thibault <[1]samuel.thibault@inria.fr>
> wrote:
> > > For some matrix size which I can say matrix with medium size, I
> > > have the following message which cause application to stuck and not
> > > continue
> > > execution.
> > > [starpu][starpu_memchunk_tidy] Low memory left on node RAM 0 (6405MiB
> > > over
> > > 128808MiB).
> > So StarPU is lacking memory. Do you have OOC enabled?
> I am not enabling OOC.
If your computation does not fit in the memory, you need to enable OOC
for StarPU to be able to evict some data to disk.
Samuel
Haut de le page
