Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Emmanuel Agullo <emmanuel.agullo@inria.fr>, Ludovic Courtes <ludovic.courtes@inria.fr>
  • Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
  • Date: Tue, 1 Sep 2020 12:07:33 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 27/08/2020 11:23, Emmanuel Agullo wrote:
> Hello,
> Thanks Florent for the suggestion.
>> Carrément, ou simplement rajouter fxt à « starpu-simgrid » si c’est pas
>> utile d’avoir les deux variantes.
> Good idea, Ludo. Indeed, in the starpu-simgrid case, the fxt overhead is
> much
> less critical than in the actual starpu case, and it might not be worth
> maintaining two separate guix packages.
> Maybe the only point is to make sure the user is aware that fxt is around
> so
> that he / she thinks to play with the STARPU_FXT_TRACE environment variable
> ( https://files.inria.fr/starpu/doc/html/OfflinePerformanceTools.html )
> in order to disable them at runtime. One way to make sure the user is aware
> of that is to name the (guix) package accordingly, for instance
> starpu-simgrid-fxt . This would be consistent with the starpu-fxt package
> naming. (And there would not be a starpu-simgrid (guix) package anymore.)
> Best regards,
> Manu
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Hello,
I just did the update. starpu-simgrid no longer exists, there is now a
package starpu-simgrid-fxt.
Cheers,
Nathalie
Dr Nathalie Furmento Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
Haut de le page
