Archives de la liste
Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
Chronologique Discussions
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: Mathieu Verite <mathieu.verite@inria.fr>, Ludovic Courtes <ludovic.courtes@inria.fr>, starpu-devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
- Date: Tue, 1 Sep 2020 16:13:10 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Nathalie,
> I just did the update. starpu-simgrid no longer exists, there is now a
> package starpu-simgrid-fxt.
Thanks much!
According to: https://gitlab.inria.fr/guix-hpc/guix-hpc/-/jobs/742257
it was breaking "guix pull", because starpu+simgrid no longer
exists. I guess it was due to the chameleon-simgrid package which shall
now depend on "starpu+simgrid+fxt":
https://gitlab.inria.fr/guix-hpc/guix-hpc/-/commit/33d590427653f28b21724f9e8ccac96c766390d0
It seems that it does fix the "guix pull" step:
https://gitlab.inria.fr/guix-hpc/guix-hpc/-/jobs/742726
However, "guix build starpu-simgrid-fxt" fails.
You'll find below an extraction of the error log occurring in the "make
check" step.
Tell me please if the full log might be useful (in which case I shall send it
in a private thread?).
In any case, thanks much for all this!
Best,
Manu
PS: here is a short extraction of the error log if it may help
Testsuite summary for StarPU 1.3.5
# TOTAL: 76
# PASS: 38
# SKIP: 37
# XFAIL: 0
# FAIL: 1
# XPASS: 0
# ERROR: 0
See tests/test-suite.log
Please report to starpu-devel@lists.gforge.inria.fr
make[5]: *** [Makefile:9167: test-suite.log] Error 1
make[5]: Leaving directory
'/tmp/guix-build-starpu-simgrid-fxt-1.3.5.drv-0/starpu-1.3.5-checkout/tests'
make[4]: *** [Makefile:9275: check-TESTS] Error 2
make[4]: Leaving directory
make[3]: *** [Makefile:11012: check-am] Error 2
make[3]: Leaving directory
make[2]: *** [Makefile:9059: check-recursive] Error 1
make[2]: Leaving directory
make[1]: *** [Makefile:11014: check] Error 2
make[1]: Leaving directory
make: *** [Makefile:829: check-recursive] Error 1
Test suite failed, dumping logs.
--- ./tests/test-suite.log --------------------------------------------------
StarPU 1.3.5: tests/test-suite.log
# TOTAL: 76
# PASS: 38
# SKIP: 37
# XFAIL: 0
# FAIL: 1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
FAIL: overlap/overlap.sh
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Nathalie Furmento, 01/09/2020
- <Suite(s) possible(s)>
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Emmanuel Agullo, 01/09/2020
