Archives de la liste
Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Emmanuel Agullo <emmanuel.agullo@inria.fr>
- Cc: Mathieu Verite <mathieu.verite@inria.fr>, Ludovic Courtes <ludovic.courtes@inria.fr>, starpu-devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
- Date: Tue, 1 Sep 2020 18:00:26 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
I fixed the package starpu-simgrid-fxt, it was missing a python dependency.
Sorry, i should have tested before committing and pushing.
Cheers,
Nathalie
On 01/09/2020 16:13, Emmanuel Agullo wrote:
> Hello Nathalie,
>> I just did the update. starpu-simgrid no longer exists, there is now a
>> package starpu-simgrid-fxt.
> Thanks much!
> According to: https://gitlab.inria.fr/guix-hpc/guix-hpc/-/jobs/742257
> it was breaking "guix pull", because starpu+simgrid no longer
> exists. I guess it was due to the chameleon-simgrid package which shall
> now depend on "starpu+simgrid+fxt":
> https://gitlab.inria.fr/guix-hpc/guix-hpc/-/commit/33d590427653f28b21724f9e8ccac96c766390d0
> It seems that it does fix the "guix pull" step:
> https://gitlab.inria.fr/guix-hpc/guix-hpc/-/jobs/742726
> However, "guix build starpu-simgrid-fxt" fails.
> You'll find below an extraction of the error log occurring in the "make
> check" step.
> Tell me please if the full log might be useful (in which case I shall send
> it
> in a private thread?).
> In any case, thanks much for all this!
> Best,
> Manu
> PS: here is a short extraction of the error log if it may help
> Testsuite summary for StarPU 1.3.5
> # TOTAL: 76
> # PASS: 38
> # SKIP: 37
> # XFAIL: 0
> # FAIL: 1
> # XPASS: 0
> # ERROR: 0
> See tests/test-suite.log
> Please report to starpu-devel@lists.gforge.inria.fr
> make[5]: *** [Makefile:9167: test-suite.log] Error 1
> make[5]: Leaving directory
> '/tmp/guix-build-starpu-simgrid-fxt-1.3.5.drv-0/starpu-1.3.5-checkout/tests'
> make[4]: *** [Makefile:9275: check-TESTS] Error 2
> make[4]: Leaving directory
> make[3]: *** [Makefile:11012: check-am] Error 2
> make[3]: Leaving directory
> make[2]: *** [Makefile:9059: check-recursive] Error 1
> make[2]: Leaving directory
> make[1]: *** [Makefile:11014: check] Error 2
> make[1]: Leaving directory
> make: *** [Makefile:829: check-recursive] Error 1
> Test suite failed, dumping logs.
> --- ./tests/test-suite.log
> StarPU 1.3.5: tests/test-suite.log
> # TOTAL: 76
> # PASS: 38
> # SKIP: 37
> # XFAIL: 0
> # FAIL: 1
> # XPASS: 0
> # ERROR: 0
> .. contents:: :depth: 2
> FAIL: overlap/overlap.sh
Dr Nathalie Furmento Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Nathalie Furmento, 01/09/2020
- <Suite(s) possible(s)>
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Emmanuel Agullo, 01/09/2020
