Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU and mingw64 error
Archives de la liste
Chronologique Discussions
  • To: Rafal Brzegowy <rafal.brzegowy@yahoo.com>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU and mingw64 error
  • Date: Fri, 18 Sep 2020 13:45:28 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Rafal Brzegowy, le ven. 18 sept. 2020 11:27:25 +0000, a ecrit:
> I have one more question related to StarPU, when I compile CaluliuX with the
> StarPU dynamic library everything works, but with the static (.a) library
> this
> errors occurs (any advice):
What command line do you use to link?
Did you use the output of pkg-config --static --libs to link? It would contain
the required -lws2_32 etc. While dynamic linking can often be fine with
a manual -lstarpu1.3, this is really not good practice, and the output
of pkg-config should really be used.
Samuel
Haut de le page
