Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU and mingw64 error
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU and mingw64 error
  • Date: Fri, 18 Sep 2020 11:53:16 +0000 (UTC)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=rafal.brzegowy@yahoo.com; spf=Pass smtp.mailfrom=rafal.brzegowy@yahoo.com; spf=None smtp.helo=postmaster@sonic306-1.consmr.mail.bf2.yahoo.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I added -lws2_32 and -lssp and now it works.
Thank you
W piątek, 18 września 2020, 13:45:49 CEST, Samuel Thibault <samuel.thibault@inria.fr> napisał(-a):
Hello,
Rafal Brzegowy, le ven. 18 sept. 2020 11:27:25 +0000, a ecrit:
> I have one more question related to StarPU, when I compile CaluliuX with the
> StarPU dynamic library everything works, but with the static (.a) library this
> errors occurs (any advice):
What command line do you use to link?
Did you use the output of pkg-config --static --libs to link? It would contain
the required -lws2_32 etc. While dynamic linking can often be fine with
a manual -lstarpu1.3, this is really not good practice, and the output
of pkg-config should really be used.
Samuel
Haut de le page
