Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU and mingw64 error
- Date: Sat, 19 Sep 2020 12:09:14 +0000 (UTC)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rafal.brzegowy@yahoo.com; spf=Pass smtp.mailfrom=rafal.brzegowy@yahoo.com; spf=None smtp.helo=postmaster@sonic306-1.consmr.mail.bf2.yahoo.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
Now I have this error, I add OpenCL (AMD):
cl_createbuffer.c:118:14: error: implicit declaration of function 'valloc'; did you mean 'malloc'? [-Werror=implicit-function-declaration]
118 | mem->ptr = valloc(size);
| malloc
Rafal
W piątek, 18 września 2020, 13:53:16 CEST, Rafal Brzegowy <rafal.brzegowy@yahoo.com> napisał(-a):
Hi,
I added -lws2_32 and -lssp and now it works.
Thank you
W piątek, 18 września 2020, 13:45:49 CEST, Samuel Thibault <samuel.thibault@inria.fr> napisał(-a):
Hello,
Rafal Brzegowy, le ven. 18 sept. 2020 11:27:25 +0000, a ecrit:
> I have one more question related to StarPU, when I compile CaluliuX with the
> StarPU dynamic library everything works, but with the static (.a) library this
> errors occurs (any advice):
What command line do you use to link?
Did you use the output of pkg-config --static --libs to link? It would contain
the required -lws2_32 etc. While dynamic linking can often be fine with
a manual -lstarpu1.3, this is really not good practice, and the output
of pkg-config should really be used.
Samuel
Samuel
- [Starpu-devel] StarPU and mingw64 error, Rafal Brzegowy, 18/09/2020
- Re: [Starpu-devel] StarPU and mingw64 error, Nathalie Furmento, 18/09/2020
- Re: [Starpu-devel] StarPU and mingw64 error, Rafal Brzegowy, 18/09/2020
- Re: [Starpu-devel] StarPU and mingw64 error, Samuel Thibault, 18/09/2020
- Re: [Starpu-devel] StarPU and mingw64 error, Rafal Brzegowy, 19/09/2020
- Re: [Starpu-devel] StarPU and mingw64 error, Samuel Thibault, 19/09/2020
