Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python
Archives de la liste
Chronologique Discussions
  • To: 高家隆 <gaojialong@nudt.edu.cn>
  • Cc: starpu-devel@inria.fr
  • Subject: Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python
  • Date: Mon, 6 Nov 2023 10:31:54 +0100
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
  • Organization: I am not organized
Hello,
高家隆, le lun. 06 nov. 2023 14:51:20 +0800, a ecrit:
> File "/usr/local/lib/python3.10/site-packages/starpu/__init__.py",
> line
> 17, in <module>
> from . import starpupy
> ImportError: /usr/local/lib/python3.10/site-packages/starpu/
> starpupy.cpython-310-x86_64-linux-gnu.so: undefined symbol:
> starpu_save_history_based_model
This looks like you are mixing different versions of StarPU?
You can make sure which libstarpu is actually used by running
ldd
/usr/local/lib/python3.10/site-packages/starpu/starpupy.cpython-310-x86_64-linux-gnu.so
and check that the starpu_save_history_based_model symbol really is in
the libstarpu that is actually getting loaded, or fix your
LD_LIBRARY_PATH in order to load the proper version.
Samuel
Haut de le page
