Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: 高家隆 <gaojialong@nudt.edu.cn>
  • Cc: StarPU Support Team <starpu-devel@inria.fr>
  • Subject: Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python
  • Date: Mon, 6 Nov 2023 11:27:57 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-sdr: 6548bfaf_IaGd6OVEZNxX2cKSzwnJp1ct1sWNeUZY9GZZVEN/cRhCxL8 s1vDD8I2ZH4dV+zEvRRBCVOHFWQ0EpnS7IE9bKw==
Can you check that the starpu_save_history_based_model symbol really is in
the libstarpu that is actually getting loaded ?
and please also tell us which branch / commit version of StarPU you are using
Cheers,
Nathalie
Le 06/11/2023 à 10:40, 高家隆 a écrit :
by running "ldd
/usr/local/lib/python3.10/site-packages/starpu/starpupy.cpython-310-x86_64-linux-gnu.so"
here is what I got:
linux-vdso.so.1 (0x00007ffd3f9db000)
libstarpu-1.4.so.1 => /usr/local/lib/libstarpu-1.4.so.1
(0x00007efe50600000)
libpython3.10.so.1.0 => /lib/x86_64-linux-gnu/libpython3.10.so.1.0
(0x00007efe50000000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007efe4fc00000)
libOpenCL.so.1 =>
/usr/local/cuda/targets/x86_64-linux/lib/libOpenCL.so.1 (0x00007efe4f800000)
libfxt.so.2 => /lib/x86_64-linux-gnu/libfxt.so.2 (0x00007efe50a61000)
libsimgrid.so.3.34.1 => /opt/simgrid/lib/libsimgrid.so.3.34.1
(0x00007efe4f000000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6
(0x00007efe4ec00000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007efe50978000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1
(0x00007efe50958000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1
(0x00007efe50927000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007efe5090b000)
/lib64/ld-linux-x86-64.so.2 (0x00007efe50aab000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007efe50904000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
(0x00007efe508ff000)
libboost_context.so.1.74.0 =>
/lib/x86_64-linux-gnu/libboost_context.so.1.74.0 (0x00007efe505fb000)
libboost_stacktrace_backtrace.so.1.74.0 =>
/lib/x86_64-linux-gnu/libboost_stacktrace_backtrace.so.1.74.0
(0x00007efe505e5000)
libns3.39-csma-default.so => /usr/local/lib/libns3.39-csma-default.so
(0x00007efe4ff8f000)
libns3.39-network-default.so =>
/usr/local/lib/libns3.39-network-default.so (0x00007efe4e800000)
libns3.39-point-to-point-default.so =>
/usr/local/lib/libns3.39-point-to-point-default.so (0x00007efe4ff08000)
libns3.39-core-default.so => /usr/local/lib/libns3.39-core-default.so
(0x00007efe4e400000)
libns3.39-applications-default.so =>
/usr/local/lib/libns3.39-applications-default.so (0x00007efe4fa87000)
libns3.39-internet-default.so =>
/usr/local/lib/libns3.39-internet-default.so (0x00007efe4dc00000)
libns3.39-wifi-default.so => /usr/local/lib/libns3.39-wifi-default.so
(0x00007efe4d200000)
libns3.39-mobility-default.so =>
/usr/local/lib/libns3.39-mobility-default.so (0x00007efe4fe46000)
libevent-2.1.so.7 => /lib/x86_64-linux-gnu/libevent-2.1.so.7
(0x00007efe4fa33000)
libgfortran.so.5 => /lib/x86_64-linux-gnu/libgfortran.so.5
(0x00007efe4ce00000)
libns3.39-stats-default.so =>
/usr/local/lib/libns3.39-stats-default.so (0x00007efe4f727000)
libgsl.so.27 => /lib/x86_64-linux-gnu/libgsl.so.27
(0x00007efe4ca00000)
libgslcblas.so.0 => /lib/x86_64-linux-gnu/libgslcblas.so.0
(0x00007efe4f6e5000)
libns3.39-mpi-default.so => /usr/local/lib/libns3.39-mpi-default.so
(0x00007efe4f697000)
libmpi_cxx.so.40 => /lib/x86_64-linux-gnu/libmpi_cxx.so.40
(0x00007efe4fe2c000)
libmpi.so.40 => /lib/x86_64-linux-gnu/libmpi.so.40
(0x00007efe4eec9000)
libns3.39-bridge-default.so =>
/usr/local/lib/libns3.39-bridge-default.so (0x00007efe4ee9c000)
libns3.39-traffic-control-default.so =>
/usr/local/lib/libns3.39-traffic-control-default.so (0x00007efe4eaba000)
libns3.39-energy-default.so =>
/usr/local/lib/libns3.39-energy-default.so (0x00007efe4e77d000)
libns3.39-spectrum-default.so =>
/usr/local/lib/libns3.39-spectrum-default.so (0x00007efe4c86d000)
libns3.39-antenna-default.so =>
/usr/local/lib/libns3.39-antenna-default.so (0x00007efe4ee6d000)
libns3.39-propagation-default.so =>
/usr/local/lib/libns3.39-propagation-default.so (0x00007efe4e6d1000)
libquadmath.so.0 => /lib/x86_64-linux-gnu/libquadmath.so.0
(0x00007efe4e689000)
libsqlite3.so.0 => /lib/x86_64-linux-gnu/libsqlite3.so.0
(0x00007efe4c720000)
libopen-pal.so.40 => /lib/x86_64-linux-gnu/libopen-pal.so.40
(0x00007efe4e34d000)
libopen-rte.so.40 => /lib/x86_64-linux-gnu/libopen-rte.so.40
(0x00007efe4db43000)
libhwloc.so.15 => /lib/x86_64-linux-gnu/libhwloc.so.15
(0x00007efe4e62d000)
libevent_core-2.1.so.7 =>
/lib/x86_64-linux-gnu/libevent_core-2.1.so.7 (0x00007efe4ee38000)
libevent_pthreads-2.1.so.7 =>
/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7 (0x00007efe4fa2e000)
libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1
(0x00007efe4ea90000)
And the default version seems to be starpu-1.4.
-----原始郵件-----
發件人: "Samuel Thibault" <samuel.thibault@inria.fr>
發送時間:2023-11-06 17:31:54 (星期一)
收件人: 高家隆 <gaojialong@nudt.edu.cn>
抄送: starpu-devel@inria.fr
主題: Re: [starpu-devel] Subject: Feedback on ImportError when importing
"starpu" in Python
Hello,
高家隆, le lun. 06 nov. 2023 14:51:20 +0800, a ecrit:
File "/usr/local/lib/python3.10/site-packages/starpu/__init__.py", line
17, in <module>
from . import starpupy
ImportError: /usr/local/lib/python3.10/site-packages/starpu/
starpupy.cpython-310-x86_64-linux-gnu.so: undefined symbol:
This looks like you are mixing different versions of StarPU?
You can make sure which libstarpu is actually used by running
ldd
and check that the starpu_save_history_based_model symbol really is in
the libstarpu that is actually getting loaded, or fix your
LD_LIBRARY_PATH in order to load the proper version.
Samuel
Dr Nathalie Furmento Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
Haut de le page
