Archives de la liste
Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: 高家隆 <gaojialong@nudt.edu.cn>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python
- Date: Mon, 6 Nov 2023 11:49:05 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-sdr: 6548c4a2_3BAwsp/T0lrBM5dqSbmqnLO9PeoVZl3jJfFYLrazijHySxR Nu45IbuwlvB2ywTGzzzATJNTlUfUBk47FqzlK9w==
No, we asked if the symbol is in the library ?
objdump -T /usr/local/lib/libstarpu-1.4.so.1 | grep starpu_save_history_based_model
Thanks !
Le 06/11/2023 à 11:41, 高家隆 a écrit :
Sure, I find this function in starpu/src/core/perfmodel/perfmodel_history.c
line1227 (Under MACRO #ifndef STARPU_SIMGRID)
and the branch and commit we can see:
starpu$ git log
commit 0ed088ceff3cdb71dd2c355caf5098e4f0213c81 (HEAD -> master,
origin/master, origin/HEAD)
Author: Nathalie Furmento <nathalie.furmento@labri.fr>
Date: Thu Nov 2 16:40:16 2023 +0100
fixes for parallel workers
commit f5192aaceaa7dfcc0fcaa57f192156e534198011
Date: Thu Nov 2 13:59:52 2023 +0000
Specify the number of cores in the architecture name
This changes the name of the combination written in the perfmodel file to include its number of cores. Files with the previous format can still be read and loaded correctly and files written with the new format can be read with a previous code.
commit 0e3a32b5292558a044b4b3fa0eb49245ad3f0d09
Date: Thu Nov 2 11:49:29 2023 +0100
check function hwloc_type_sscanf is available
-----原始郵件-----
發件人: "Nathalie Furmento" <nathalie.furmento@labri.fr>
發送時間:2023-11-06 18:27:57 (星期一)
收件人: 高家隆 <gaojialong@nudt.edu.cn>
抄送: "StarPU Support Team" <starpu-devel@inria.fr>
主題: Re: [starpu-devel] Subject: Feedback on ImportError when importing
"starpu" in Python
Can you check that the starpu_save_history_based_model symbol really is in
the libstarpu that is actually getting loaded ?
and please also tell us which branch / commit version of StarPU you are using
Cheers,
Nathalie
Le 06/11/2023 à 10:40, 高家隆 a écrit :
by running "ldd
/usr/local/lib/python3.10/site-packages/starpu/starpupy.cpython-310-x86_64-linux-gnu.so"
here is what I got:
linux-vdso.so.1 (0x00007ffd3f9db000)
libstarpu-1.4.so.1 => /usr/local/lib/libstarpu-1.4.so.1
(0x00007efe50600000)
libpython3.10.so.1.0 => /lib/x86_64-linux-gnu/libpython3.10.so.1.0
(0x00007efe50000000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007efe4fc00000)
libOpenCL.so.1 =>
/usr/local/cuda/targets/x86_64-linux/lib/libOpenCL.so.1 (0x00007efe4f800000)
libfxt.so.2 => /lib/x86_64-linux-gnu/libfxt.so.2 (0x00007efe50a61000)
libsimgrid.so.3.34.1 => /opt/simgrid/lib/libsimgrid.so.3.34.1
(0x00007efe4f000000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6
(0x00007efe4ec00000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007efe50978000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1
(0x00007efe50958000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1
(0x00007efe50927000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007efe5090b000)
/lib64/ld-linux-x86-64.so.2 (0x00007efe50aab000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007efe50904000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
(0x00007efe508ff000)
libboost_context.so.1.74.0 =>
/lib/x86_64-linux-gnu/libboost_context.so.1.74.0 (0x00007efe505fb000)
libboost_stacktrace_backtrace.so.1.74.0 =>
/lib/x86_64-linux-gnu/libboost_stacktrace_backtrace.so.1.74.0
(0x00007efe505e5000)
libns3.39-csma-default.so => /usr/local/lib/libns3.39-csma-default.so
(0x00007efe4ff8f000)
libns3.39-network-default.so =>
/usr/local/lib/libns3.39-network-default.so (0x00007efe4e800000)
libns3.39-point-to-point-default.so =>
/usr/local/lib/libns3.39-point-to-point-default.so (0x00007efe4ff08000)
libns3.39-core-default.so => /usr/local/lib/libns3.39-core-default.so
(0x00007efe4e400000)
libns3.39-applications-default.so =>
/usr/local/lib/libns3.39-applications-default.so (0x00007efe4fa87000)
libns3.39-internet-default.so =>
/usr/local/lib/libns3.39-internet-default.so (0x00007efe4dc00000)
libns3.39-wifi-default.so => /usr/local/lib/libns3.39-wifi-default.so
(0x00007efe4d200000)
libns3.39-mobility-default.so =>
/usr/local/lib/libns3.39-mobility-default.so (0x00007efe4fe46000)
libevent-2.1.so.7 => /lib/x86_64-linux-gnu/libevent-2.1.so.7
(0x00007efe4fa33000)
libgfortran.so.5 => /lib/x86_64-linux-gnu/libgfortran.so.5
(0x00007efe4ce00000)
libns3.39-stats-default.so =>
/usr/local/lib/libns3.39-stats-default.so (0x00007efe4f727000)
libgsl.so.27 => /lib/x86_64-linux-gnu/libgsl.so.27
(0x00007efe4ca00000)
libgslcblas.so.0 => /lib/x86_64-linux-gnu/libgslcblas.so.0
(0x00007efe4f6e5000)
libns3.39-mpi-default.so => /usr/local/lib/libns3.39-mpi-default.so
(0x00007efe4f697000)
libmpi_cxx.so.40 => /lib/x86_64-linux-gnu/libmpi_cxx.so.40
(0x00007efe4fe2c000)
libmpi.so.40 => /lib/x86_64-linux-gnu/libmpi.so.40
(0x00007efe4eec9000)
libns3.39-bridge-default.so =>
/usr/local/lib/libns3.39-bridge-default.so (0x00007efe4ee9c000)
libns3.39-traffic-control-default.so =>
/usr/local/lib/libns3.39-traffic-control-default.so (0x00007efe4eaba000)
libns3.39-energy-default.so =>
/usr/local/lib/libns3.39-energy-default.so (0x00007efe4e77d000)
libns3.39-spectrum-default.so =>
/usr/local/lib/libns3.39-spectrum-default.so (0x00007efe4c86d000)
libns3.39-antenna-default.so =>
/usr/local/lib/libns3.39-antenna-default.so (0x00007efe4ee6d000)
libns3.39-propagation-default.so =>
/usr/local/lib/libns3.39-propagation-default.so (0x00007efe4e6d1000)
libquadmath.so.0 => /lib/x86_64-linux-gnu/libquadmath.so.0
(0x00007efe4e689000)
libsqlite3.so.0 => /lib/x86_64-linux-gnu/libsqlite3.so.0
(0x00007efe4c720000)
libopen-pal.so.40 => /lib/x86_64-linux-gnu/libopen-pal.so.40
(0x00007efe4e34d000)
libopen-rte.so.40 => /lib/x86_64-linux-gnu/libopen-rte.so.40
(0x00007efe4db43000)
libhwloc.so.15 => /lib/x86_64-linux-gnu/libhwloc.so.15
(0x00007efe4e62d000)
libevent_core-2.1.so.7 =>
/lib/x86_64-linux-gnu/libevent_core-2.1.so.7 (0x00007efe4ee38000)
libevent_pthreads-2.1.so.7 =>
/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7 (0x00007efe4fa2e000)
libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1
(0x00007efe4ea90000)
And the default version seems to be starpu-1.4.
-----原始郵件-----
發件人: "Samuel Thibault" <samuel.thibault@inria.fr>
發送時間:2023-11-06 17:31:54 (星期一)
抄送: starpu-devel@inria.fr
"starpu" in Python
Hello,
高家隆, le lun. 06 nov. 2023 14:51:20 +0800, a ecrit:
File "/usr/local/lib/python3.10/site-packages/starpu/__init__.py",This looks like you are mixing different versions of StarPU?
line
17, in <module>
from . import starpupy
ImportError: /usr/local/lib/python3.10/site-packages/starpu/
starpupy.cpython-310-x86_64-linux-gnu.so: undefined symbol:
You can make sure which libstarpu is actually used by running
ldd
and check that the starpu_save_history_based_model symbol really is in
the libstarpu that is actually getting loaded, or fix your
LD_LIBRARY_PATH in order to load the proper version.
Samuel
Dr Nathalie Furmento Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, 高家隆, 06/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, Nathalie Furmento, 06/11/2023
- Message indisponible
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, Samuel Thibault, 06/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, 高家隆, 06/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, Samuel Thibault, 07/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, 高家隆, 08/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, Samuel Thibault, 08/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, 高家隆, 09/11/2023
- Re: [starpu-devel] Subject: Feedback on ImportError when importing "starpu" in Python, Samuel Thibault, 09/11/2023
