Archives de la liste
- To: typographie AT listes.irisa.fr
- Subject: Re: [typo] Chine-collé ?
- Date: Tue, 28 Jan 2020 00:05:09 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=cls AT fornax.fr; spf=Pass smtp.mailfrom=cls AT fornax.fr; spf=None smtp.helo=postmaster AT 10.mo173.mail-out.ovh.net
- Ironport-phdr: 9a23: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
Bon. Après avoir lu les deux sources écrites fort peu fiables en effet, je pense pouvoir affirmer que la seule façon d'écrire l'_expression_ correctement (selon le credo orthotypographique de cette liste) est chine collé. Chine sans majuscule mis pour papier de Chine, comme on dit bordeaux pour vin de Bordeaux. Et collé sans trait d'union parce qu'il ne s'agit pas d'un mot composé mais d'une réduction de l'_expression_ : papier de Chine collé ou encollé. Il s'agit-là d'une variante (pour précautionneux ou débutants) d'une technique de tirage en taille-douce appelée chine (ou japon) appliqué qui consiste à placer un papier mince et de très bonne qualité, très légèrement humidifié, directement sur une plaque encrée (papier aux dimensions exacte de la plaque) puis à poser sur le tout un papier gravure épais, plus fortement humidifié, et de plus grandes dimensions pour donner des marges à la gravure. Le passage entre les deux rouleaux de la presse va coller les deux papiers entre eux sous l'effet de la forte pression. L chine collé en est une variante où l'on encolle le papier de Chine sur sa face qui ne touche pas la plaque, afin d'assurer une adhérence maximale.
J'espère n'avoir pas été trop chiant sur cette liste avec mes
explications technique. On ne sait jamais, si ça pouvait servir...
cls AT fornax.fr
http://www.fornax.fr
http://www.cls-typo.fr
________
Sent from my letterpress machine connected to my pedals computer.
Le 27 janv. 2020 à 20:25, CLS <cls AT fornax.fr> a écrit :
On parle bien ici de la même chose que ce que j'évoquais dans ma réponse en privé, Jacques. Peut-on savoir quelles sont tes sources... et ton estimation au sujet de leur fiabilité technique ?
La liste Typo — discussions typographiques Les archives : https://sympa.inria.fr/sympa/arc/typographie Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
- [typo] Chine-collé ?, Jacques ANDRÉ, 27/01/2020
- Re: [typo] Chine-collé ?, Anne Guilleaume, 27/01/2020
- Re: [typo] Chine-collé ?, Jacques ANDRÉ, 27/01/2020
- Re: [typo] Chine-collé ?, CLS, 27/01/2020
- Re: [typo] Chine-collé ?, CLS, 28/01/2020
- Re: [typo] chine collé !, Jacques ANDRÉ, 28/01/2020
- Re: [typo] chine collé !, CLS, 28/01/2020
- Re: [typo] chine collé !, Jacques Melot, 28/01/2020
- Re: [typo] Chine-collé ?, Jacques Melot, 28/01/2020
Archives gérées par MHonArc 2.6.18.
