Archives de la liste
- To: typographie AT inria.fr
- Subject: Re: [typo] nombres négatifs
- Date: Fri, 11 Dec 2020 16:35:59 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ribeyre.n AT gmail.com; spf=Pass smtp.mailfrom=ribeyre.n AT gmail.com; spf=None smtp.helo=postmaster AT mail-lj1-f181.google.com
- Ironport-phdr: 9a23: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
Bonjour a tous,
J'ai une question presque connexe, cela porte sur les nombres avec beaucoup de de décimales (on en trouve souvent dans les documents financiers par exemple).
Doit ont utiliser un séparateur de milliers pour les chiffres derrière la virgule ?
1_234,567_890
D'expérience je dirais que non... Mais je préfère l'avis de personnes éclairées à ma modeste expérience.
Merci.
Le ven. 11 déc. 2020 à 14:36, Alain Fossé <alainbfosse AT gmail.com> a écrit :
Merci Paul.Le ven. 11 déc. 2020 à 14:23, Paul Guertin <paul AT guertin.net> a écrit :De la part de ce matheux, aucune hésitation : pas d'espace
entre le signe et le nombre. Donc « -12,4 ℃ ; -10 % ».
Paul Guertin
Dixit Alain Fossé (2020-12-11 7:13 a.m.):
> Bonjour
> Comment doit-on écrire des températures ou des pourcentages négatifs ?
> « − 12,4 ℃ ; − 10 % », avec espace insécable entre signe et nombre,
> ou « −12,4 ℃ ; −10 % », sans espace entre signe et nombre ?
> Je pencherais pour l’espace…
> Merci et bonne journée.
> Cordialement.
> Alain Fossé, Angers
La liste Typo — discussions typographiques
Les archives : https://sympa.inria.fr/sympa/arc/typographie
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
- [typo] nombres négatifs, Alain Fossé, 11/12/2020
- Re: [typo] nombres négatifs, Emmanuel Curis, 11/12/2020
- Re: [typo] nombres négatifs, Jacques ANDRÉ, 11/12/2020
- Re: [typo] nombres négatifs, Alain Fossé, 11/12/2020
- Re: [typo] nombres négatifs, Paul Guertin, 11/12/2020
- Re: [typo] nombres négatifs, Nicolas Ribeyre, 11/12/2020
- Re: [typo] nombres négatifs, Thierry Bouche, 11/12/2020
- Re: [typo] nombres négatifs, Amalric Oriet, 11/12/2020
