Archives de la liste
- To: typographie AT inria.fr
- Subject: Re: [typo] Tsunami ou pas...
- Date: Fri, 11 Dec 2020 16:17:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=patlist AT au-soleil.org; spf=Pass smtp.mailfrom=patlist AT au-soleil.org; spf=None smtp.helo=postmaster AT smtp-42af.mail.infomaniak.ch
- Ironport-phdr: 9a23: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
- Organization: Perso
J'ai vécu de très près un raz-de-marée dont aucune éruption ni séisme n'étaient à l'origine, mais un effondrement de surface (sous-marine) dont je ne sais s'il faut le qualifier de «choc violent».
Donc probablement pas tsunami.
Toujours est-il que voir la mer se retirer plus revenir en silence sous un ciel gris et emporter dans les airs quelques baraques de plage comme fétus fut particulièrement spectaculaire.
J'étais presque au bout de la rue de la photo ici (juste à la pointe de l’Îlette, pour les Antibois)
https://www.nicematin.com/faits-divers/video-il-y-a-40-ans-un-monstrueux-raz-de-maree-devastait-la-cote-dazur-et-tuait-11-personnes-175661
Ma petite voiture garée dans une rue proche n'a pas aimé baigner dans l'eau de mer jusqu'à mi-portières...
Pardon pour la digression...
Le 11/12/2020 à 15:13, Paul Guertin a
écrit :
On
2020/12/11 06:57, Jacques Melot wrote:
[J. M.] Dans la mesure où c'est un emprunt culturel à l'anglais, c'est bien, par définition même, un anglicisme, quelle que soit l'origine du mot. Autre exemple :/tsunami/ maintenant employé à la place du français/raz-de-marée/ (qu'il fait disparaître) est un anglicisme, même si l'anglais a emprunté ce mot au japonais.
Si « raz-de-marée » venait à disparaître, on perdrait une
distinction utile.
« Raz-de-marée » est plus général que « tsunami ». Les deux
désignent une énorme vague qui envahit le littoral, mais un
tsunami est provoqué par un choc violent (éruption, séisme,
etc.), tandis qu'un raz-de-marée peut aussi être causé par
une tempête en haute mer.
Donc tous les tsunamis sont des raz-de-marée, mais certains
raz-de-marée ne sont pas des tsunamis.
Paul Guertin
La liste Typo — discussions typographiques Les archives : https://sympa.inria.fr/sympa/arc/typographie Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
-- Patrick
- Re: [typo] Doute de typo, (suite)
- Re: [typo] Doute de typo, Nicolas Ribeyre, 09/12/2020
- Re: [typo] Doute de typo, Brigitte Gaudin de Gaullier - Freelance Translator, 09/12/2020
- Re: [typo] Doute de typo, jtombeur, 09/12/2020
- Re: [typo] Doute de typo, Jacques Melot, 09/12/2020
- Re: [typo] Doute de typo, Amalric Oriet, 09/12/2020
- Re: [typo] Doute de typo, Philippe-André Lorin, 09/12/2020
- Re: [typo] Doute de typo, echamontin, 11/12/2020
- Re: [typo] Doute de typo, Jacques Melot, 11/12/2020
- Re: [typo] Doute de typo, Paul Guertin, 11/12/2020
- Re: [typo] Tsunami ou pas..., Patrick, 11/12/2020
- Re: [typo] Doute de typo, Amalric Oriet, 11/12/2020
- Re: [typo] Doute de typo, Brigitte Gaudin de Gaullier - Freelance Translator, 15/12/2020
- Message indisponible
- Re: [typo] Doute de typo, Philippe-André Lorin, 11/12/2020
