Archives de la liste
- From: Olivier Randier <olivier.randier AT gmail.com>
- To: typographie AT inria.fr
- Subject: Re: [typo] Barre oblique, point virgule ou point ?
- Date: Tue, 12 Jan 2021 19:08:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=olivier.randier AT gmail.com; spf=Pass smtp.mailfrom=olivier.randier AT gmail.com; spf=None smtp.helo=postmaster AT mail-ej1-f44.google.com
- Ironport-phdr: 9a23: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
Bonjour,
A mon avis, vous pouvez très bien faire comme ceci :
Qu’est-ce que vous voyez sur cette image ?
1. -- Une cuisinière lavant manuellement la vaisselle en trois étapes. 2. -- Une cuisinière nettoyant la cuisine. 3. -- Une cuisinière qui garde un animal hors de la cuisine. 4. -- Une cuisinière jetant les déchets dans la poubelle. 5. -- Plans de travail et ustensiles propres rangés à l'envers.
Ce qui permet de répondre facilement en donnant le numéro de la réponse. Si vous numérotez les questions aussi, vous pouvez remplacer les nombres par des lettres.
Mes deux centimes
Le mar. 12 janv. 2021 à 18:55, Brigitte Gaudin de Gaullier - Freelance Translator <bgaudin AT gmail.com> a écrit :
Bonjour et bonne année !Dans un cas comme celui-ci (session de formation avec des questions et des réponses) :Q1.
Une cuisinière lavant manuellement la vaisselle en trois étapes / Une cuisinière nettoyant la cuisine / Une cuisinière qui garde un animal hors de la cuisine / Une cuisinière jetant les déchets dans la poubelle / Plans de travail et ustensiles propres rangés à l'envers.Il faut tout laisser sur la même ligne et, dans ce cas, j'avoue que j'hésite entre le point virgule et le point plutôt que la barre oblique.Qu'en pensez-vous ?P.D. : Au fait, connaissez-vous l'adresse de courriel du groupe Correction ? Il a dû changer d'adresse et je ne la retrouve pas.Cordialement,--
General Translations
Spanish, Catalan > French
Medicine & Health Translations
Spanish, Catalan, English > French
Member of ASETRAD
Mobile: +34 686 03 35 35
Skype me: bggtraductions
La liste Typo — discussions typographiques
Les archives : https://sympa.inria.fr/sympa/arc/typographie
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
____________
Olivier Randier
- [typo] L'orthotypo de Jean Méron en ligne, jtombeur, 12/01/2021
- [typo] Barre oblique, point virgule ou point ?, Brigitte Gaudin de Gaullier - Freelance Translator, 12/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Olivier Randier, 12/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Jacques Melot, 12/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Amalric Oriet, 12/01/2021
- RE: [typo] Barre oblique, point virgule ou point ?, diconoma, 12/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Benoît Leraillez, 12/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Brigitte Gaudin de Gaullier - Freelance Translator, 14/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Philippe-André Lorin, 12/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Jacques Melot, 13/01/2021
- Message indisponible
- Re: [typo] Barre oblique, point virgule ou point ?, Philippe-André Lorin, 13/01/2021
- Re: [typo] Barre oblique, point virgule ou point ?, Brigitte Gaudin de Gaullier - Freelance Translator, 20/01/2021
- [typo] En passant par..., CLS, 25/01/2021
