cado-nfs - Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
  • To: meng <qsmeng@126.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
  • Date: Mon, 22 Jul 2013 11:14:34 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
to all people on the list: please keep the cado-nfs-discuss list in cc, and
please avoid answering privately to any developer.
> Date: Fri, 19 Jul 2013 21:08:56 +0800 (CST)
> From: meng <qsmeng@126.com>
> Dear Paul Zimmermann,
> >> But another problem still exists. I succeeds in factor c90 in
> distributed mode with the two computers. With the same environment, when
> factoring rsa100, the screen says: >> 1. Info:Checking job: rsa100
> localhost 2720000 2740000 >> Warning:Dead?! >> ...... >>
> 2. Info:Retrieving `rsa100.rels.2720000-2740000.gz' from `localhost'... >>
> Warning:File `/home/greatnet/c100/rsa100.rels.2720000-2740000'
> contains no useable data. Deleting... >> ....... >> 3. Info:Starting new
> jobs... >> Info:Starting job: rsa100 localhost 2720000 2740000 >>
> >I don't know. Please can you restart cadofactor with the environment
> >variable >CADO_DEBUG set and the -v option? Then please redo manually the
> >"las" command >corresponding to rsa100.rels.2720000-2740000, and send us
> >the corresponding >file (with rsa100.poly and rsa100.roots). > >Btw, which
> >version of CADO-NFS are you using? > >Paul Zimmermann
> after CADO_DEBUG=1;export CADO_DEBUG, and restart the cadofactor.pl, I got
> the attached file myresultv. When I redo manually the las command
> /home/greatnet/meng/cado-nfs/build/localhost.localdomain/sieve/las
> -I 11 -rpowlim 2047 -apowlim 2047 -poly /tmp/rsa100.poly -fb
> /tmp/rsa100.roots -q0 2700000 -q1 2720000 -mt 2 -out
> /tmp/rsa100.rels.2700000-2720000.gz
> The screen display "illegal instruction " and I got the second attached
> file rsa100.rels.2700000-2720000.gz.
> The version I use is e4ce34.
> Thank you.
> Regards,
> Meng
did you compile the binary you use
(/home/greatnet/meng/cado-nfs/build/localhost.localdomain/sieve/las) on the
same machine where you run it? If so, please can you try with gdb as follows?
gdb --args -I 11 -rpowlim 2047 -apowlim 2047 -poly /tmp/rsa100.poly -fb
then under gdb, type "run", and when the "illegal instruction" happens, type
"where" and send us the output you get.
Paul Zimmermann
