- To: meng <qsmeng@126.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] sieving takes too much time
- Date: Tue, 16 Dec 2014 20:54:37 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
> Date: Sun, 14 Dec 2014 13:02:34 +0800 (CST)
> From: meng <qsmeng@126.com>
> Hi all,
> Using the two nonlinear polynomial given by Williams, I tried to
> factor C59 by running "./cadofactor.py params.c59" under the direction of
> Readme.nonlinear. Everything seems to be ok, but the sieving stage took too
> much time(several hours) . The screen displays the following and no
> progress:
> Info:Lattice Sieving: Adding workunit c59_sieving_91845-93845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_93845-95845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_95845-97845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_97845-99845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_99845-101845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_101845-103845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_103845-105845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_105845-107845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_107845-109845 to database
> Info:Lattice Sieving: Adding workunit c59_sieving_109845-111845 to database
> Obviously it is not normal. Would you please help to fix this problem?
> Thank you in advance.
> Best regards,
> Qingshu Meng
indeed this is not normal. I just tried with the git version and it works
(except you should not add tasks.sieve.import=/my/wonderful/path/rels,
relations are now automatically computed by las).
Apparently your clients do not fetch the workunits. Does the following work
with the git version?
zimmerma@coing:~/svn/cado-nfs$ ./scripts/cadofactor/cadofactor.py
params/params.c59
N=71641520761751435455133616475667090434063332228247871795429
tasks.workdir=/tmp/c59 slaves.hostnames=localhost
tasks.execpath=${HOME}/svn/cado-nfs/build/${MACHINE}
Paul
- [Cado-nfs-discuss] sieving takes too much time, meng, 12/14/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, paul zimmermann, 12/16/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, Shi Bai, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, meng, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, paul zimmermann, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, meng, 12/18/2014
