- To: "paul zimmermann" <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] sieving takes too much time
- Date: Fri, 19 Dec 2014 06:56:36 +0800 (CST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
With your attached params.c59, I did factor the c59 with two nonlinear polynomials. Thank you very much.
Best regards,
Meng
Best regards,
Meng
At 2014-12-17 23:57:06, "paul zimmermann" <Paul.Zimmermann@inria.fr> wrote: > Dear Meng, > >> Thank you very much for your helps. Indeed I made some progress, but still there exists error. >> with latest git version, I tried the commands with params.c59 you two suggested and the following two nonlinear polynomials as input: >> n: 71641520761751435455133616475667090434063332228247871795429 >> skew: 1.29196058385 >> c0: 8794918866367 >> c1: 4558622527656 >> c2: -4793408682249 >> c3: 3460228261843 >> Y0: -8342133927919 >> Y1: 12431783167 >> Y2: -9745365241781 >> Y3: 7034907821749 >> with the result as follows: [...] > >the resultant of your two polynomials has 79 digits, thus you need to use >similar sieving parameters as in params.c79. With the attached params.c59 it >seems to work (with the git version). > >Paul
- [Cado-nfs-discuss] sieving takes too much time, meng, 12/14/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, paul zimmermann, 12/16/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, Shi Bai, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, meng, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, paul zimmermann, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, meng, 12/18/2014
