- To: Greg Marks <marks@member.ams.org>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering
- Date: Mon, 17 Aug 2015 18:14:39 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Greg,
it seems to work with the git version (just fixed the fact that the command
line was not printed in c60.freerel.freerel.stdout.1):
zimmerma@tarte:~/svn/cado-nfs$ ./factor.sh
90377629292003121684002147101760858109247336549001090677693
tasks.sieve.freerel.threads=3
zimmerma@tarte:~/svn/cado-nfs$ head -1
/tmp/cado.hDYwnLCKdk/c60.freerel.freerel.stdout.1
# (747a3bd+) /users/caramel/zimmerma/svn/cado-nfs/build/tarte/sieve/freerel
-poly /tmp/cado.hDYwnLCKdk/c60.polyselect2.poly -renumber
/tmp/cado.hDYwnLCKdk/c60.freerel.renumber.gz -lpb0 18 -lpb1 19 -out
/tmp/cado.hDYwnLCKdk/c60.freerel.freerel.gz -t 3
Please can you check again (with the latest git version) and report here?
Paul
> Date: Sat, 8 Aug 2015 14:05:16 -0500
> From: Greg Marks <marks@member.ams.org>
> Dear Paul,
> Thank you for appended message containing the patch. I did change
> the dup2.c file as indicated in your message below, and recompiled.
> The program has been sieving successfully for perhaps a month since
> then, and I have not encountered this zero-byte problem again. So this
> probably means that problem is solved.
> Incidentally, in another message you suggested that one could speed up
> the free relation calculation when restarting a computation in a fresh
> working directory with the command:
> cadofactor.py ... tasks.sieve.freerel.threads=3
> I've tried this a few times, including with other numbers in place of
> 3, but the freerel routine uses only one core no matter what I try.
> Admittedly this isn't that important, since it's only an extra hour
> or two from time to time in a months-long computation. (There is a
> sort of psychological reason to want to speed this step along: what's
> usually happened is that I've deleted some corrupted sieving file and
> am anxious to see whether las is going to restart without errors.)
> Sincerely,
> Greg
> | Greg Marks |
> | Department of Mathematics and Computer Science |
> | St. Louis University |
> | St. Louis, MO 63103-2007 |
> | U.S.A. |
> | Phone: (314)977-7206 Fax: (314)977-1452 |
> | PGP encryption public key ID: 0x53F269E8 |
> | Web: http://gmarks.org |
> Message from paul zimmermann <Paul.Zimmermann@inria.fr>
> of June 29, 2015, 18:03:18 +0200, follows:
> > > The program now terminates with the error message appended at the bottom
> > > of this message. The file $WORKDIR/c184.duplicates1//0/dup1.1.0000.gz
> > > mentioned in the stderr below turns out to be a 20 byte file, which,
> > > when gunzipped, is a zero byte file.
> > it is a bug that a zero byte file is not accepted in dup2. I fixed this in
> > commit 73aa354 (review welcome).
> > Greg, please could you try again with this change?
> > --- a/filter/dup2.c
> > +++ b/filter/dup2.c
> > @@ -432,11 +432,18 @@ int check_whether_file_is_renumbered(const char *
> > filename, unsigned int npoly)
> > unsigned int count = 0;
> > char s[1024];
> > FILE *f_tmp = fopen_maybe_compressed (filename, "rb");
> > if (!f_tmp) {
> > fprintf(stderr, "%s: %s\n", filename, strerror(errno));
> > abort();
> > + if (feof (f_tmp)) /* file is empty */
> > + fclose_maybe_compressed (f_tmp, filename);
> > + return 1; /* an empty file might be considered as renumbered */
> > /* Look for first non-comment line */
> > while (1) {
> > char *ret = fgets (s, 1024, f_tmp);
> > Paul
> [2:application/pgp-signature Show Save:signature.asc (819B)]
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, paul zimmermann, 08/17/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, Greg Marks, 08/19/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, Pierrick Gaudry, 08/19/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, Greg Marks, 08/31/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, paul zimmermann, 08/31/2015
