- To: Greg Marks <marks@member.ams.org>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering
- Date: Wed, 19 Aug 2015 08:40:04 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
It seems that you used a new cadofactor script with an old makefb binary.
I suggest that you recompile everything from scratch with the new
downloaded version.
Also, there are currently many changes occurring in the git version,
sometimes breaking everything. It is highly recommended to check on
https://ci.inria.fr/cado/
to see if there are failures with the current git version for your
architecture / OS. For instance, at the time of writing this message, it
is a very bad idea to git pull if you have a Mac.
Pierrick
On Tue, Aug 18, 2015 at 11:57:50PM -0500, Greg Marks wrote:
> Dear Paul,
> I'm encountering into a problem with the git version, downloaded today
> from here:
> git clone https://scm.gforge.inria.fr/anonscm/git/cado-nfs/cado-nfs.git
> Running the program with the same parameter settings as before, it
> terminates with this error:
> Info:Generate Factor Base: Starting
> Warning:Command: Process with PID 9943 finished with return code 1
> Error:Generate Factor Base: Program run on server failed with exit code 1
> Error:Generate Factor Base: Command line was:
> /usr/local/cado-nfs-build/sieve/makefb -poly
> /tmp/cado.zCGBRfYgj9/c184.polyselect2.poly -lim 80000000 -maxbits 14 -out
> /tmp/cado.zCGBRfYgj9/c184.factorbase.roots.gz -t 8 >
> /tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stdout.1 2>
> /tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stderr.1
> Error:Generate Factor Base: Stderr output follows (stored in file
> /tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stderr.1):
> b'Error: parameter -alim is mandatory\nUsage:
> /usr/local/cado-nfs-build/sieve/makefb <parameters>\nThe available
> parameters are the following:\n -poly polynomial file\n -alim
> factor base bound\n -maxbits (optional) maximal number of bits of
> powers\n -out (optional) name of the output file\n -side
> (optional) create factor base for given side. Side must be 0 or 1 (default
> is 1, i.e. algebraic).\n'
> Traceback (most recent call last):
> File "/usr/local/cado-nfs/scripts/cadofactor/cadofactor.py", line 81,
> in <module>
> factors = factorjob.run()
> File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line 5251,
> in run
> last_status, last_task = self.run_next_task()
> File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line 5329,
> in run_next_task
> return [task.run(), task.title]
> File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line 2453,
> in run
> raise Exception("Program failed")
> Exception: Program failed
> I'm using a copy of /usr/local/cado-nfs/params/params.c186 (with extra
> settings appended) as the argument to cadofactor.py, which includes
> this definition:
> alim = 80000000
> Using cado-nfs-2.1.1 with the same params file, there are no problems.
> Sincerely,
> Greg
> | Greg Marks |
> | Department of Mathematics and Computer Science |
> | St. Louis University |
> | St. Louis, MO 63103-2007 |
> | U.S.A. |
> | Phone: (314)977-7206 Fax: (314)977-1452 |
> | PGP encryption public key ID: 0x53F269E8 |
> | Web: http://gmarks.org |
> Message from paul zimmermann <Paul.Zimmermann@inria.fr>
> of August 17, 2015, 18:14:39 +0200, follows:
> > Greg,
> > it seems to work with the git version (just fixed the fact that the
> > command
> > line was not printed in c60.freerel.freerel.stdout.1):
> > zimmerma@tarte:~/svn/cado-nfs$ ./factor.sh
> > 90377629292003121684002147101760858109247336549001090677693
> > tasks.sieve.freerel.threads=3
> > zimmerma@tarte:~/svn/cado-nfs$ head -1
> > /tmp/cado.hDYwnLCKdk/c60.freerel.freerel.stdout.1
> > # (747a3bd+)
> > /users/caramel/zimmerma/svn/cado-nfs/build/tarte/sieve/freerel -poly
> > /tmp/cado.hDYwnLCKdk/c60.polyselect2.poly -renumber
> > /tmp/cado.hDYwnLCKdk/c60.freerel.renumber.gz -lpb0 18 -lpb1 19 -out
> > /tmp/cado.hDYwnLCKdk/c60.freerel.freerel.gz -t 3
> > Please can you check again (with the latest git version) and report here?
> > Paul
> > > Date: Sat, 8 Aug 2015 14:05:16 -0500
> > > From: Greg Marks <marks@member.ams.org>
> > > Dear Paul,
> > > Thank you for appended message containing the patch. I did change
> > > the dup2.c file as indicated in your message below, and recompiled.
> > > The program has been sieving successfully for perhaps a month since
> > > then, and I have not encountered this zero-byte problem again. So this
> > > probably means that problem is solved.
> > > Incidentally, in another message you suggested that one could speed up
> > > the free relation calculation when restarting a computation in a fresh
> > > working directory with the command:
> > > cadofactor.py ... tasks.sieve.freerel.threads=3
> > > I've tried this a few times, including with other numbers in place of
> > > 3, but the freerel routine uses only one core no matter what I try.
> > > Admittedly this isn't that important, since it's only an extra hour
> > > or two from time to time in a months-long computation. (There is a
> > > sort of psychological reason to want to speed this step along: what's
> > > usually happened is that I've deleted some corrupted sieving file and
> > > am anxious to see whether las is going to restart without errors.)
> > > Sincerely,
> > > Greg
> > > | Greg Marks |
> > > | U.S.A. |
> > > of June 29, 2015, 18:03:18 +0200, follows:
> > > > > The program now terminates with the error message appended at the
> > > > > bottom
> > > > > of this message. The file
> > > > > $WORKDIR/c184.duplicates1//0/dup1.1.0000.gz
> > > > > mentioned in the stderr below turns out to be a 20 byte file, which,
> > > > > when gunzipped, is a zero byte file.
> > > > it is a bug that a zero byte file is not accepted in dup2. I fixed
> > > > this in
> > > > commit 73aa354 (review welcome).
> > > > Greg, please could you try again with this change?
> > > > --- a/filter/dup2.c
> > > > +++ b/filter/dup2.c
> > > > @@ -432,11 +432,18 @@ int check_whether_file_is_renumbered(const char
> > > > * filename, unsigned int npoly)
> > > > unsigned int count = 0;
> > > > char s[1024];
> > > > FILE *f_tmp = fopen_maybe_compressed (filename, "rb");
> > > > if (!f_tmp) {
> > > > fprintf(stderr, "%s: %s\n", filename, strerror(errno));
> > > > abort();
> > > > + if (feof (f_tmp)) /* file is empty */
> > > > + fclose_maybe_compressed (f_tmp, filename);
> > > > + return 1; /* an empty file might be considered as renumbered
> > > > /* Look for first non-comment line */
> > > > while (1) {
> > > > char *ret = fgets (s, 1024, f_tmp);
> > > > Paul
> > > [2:application/pgp-signature Show Save:signature.asc (819B)]
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, paul zimmermann, 08/17/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, Greg Marks, 08/19/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, Pierrick Gaudry, 08/19/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, Greg Marks, 08/31/2015
- Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering, paul zimmermann, 08/31/2015
