cado-nfs - Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering
  • To: paul zimmermann <Paul.Zimmermann@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering
  • Date: Tue, 18 Aug 2015 23:57:50 -0500
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
I'm encountering into a problem with the git version, downloaded today
from here:
git clone https://scm.gforge.inria.fr/anonscm/git/cado-nfs/cado-nfs.git
Running the program with the same parameter settings as before, it
terminates with this error:
Info:Generate Factor Base: Starting
Warning:Command: Process with PID 9943 finished with return code 1
Error:Generate Factor Base: Program run on server failed with exit code 1
Error:Generate Factor Base: Command line was:
/usr/local/cado-nfs-build/sieve/makefb -poly
/tmp/cado.zCGBRfYgj9/c184.polyselect2.poly -lim 80000000 -maxbits 14 -out
/tmp/cado.zCGBRfYgj9/c184.factorbase.roots.gz -t 8 >
/tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stdout.1 2>
/tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stderr.1
Error:Generate Factor Base: Stderr output follows (stored in file
/tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stderr.1):
b'Error: parameter -alim is mandatory\nUsage:
/usr/local/cado-nfs-build/sieve/makefb <parameters>\nThe available parameters
are the following:\n -poly polynomial file\n -alim factor
base bound\n -maxbits (optional) maximal number of bits of powers\n
-out (optional) name of the output file\n -side (optional)
create factor base for given side. Side must be 0 or 1 (default is 1, i.e.
algebraic).\n'
Traceback (most recent call last):
File "/usr/local/cado-nfs/scripts/cadofactor/cadofactor.py", line 81, in
<module>
factors = factorjob.run()
File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line 5251, in
run
last_status, last_task = self.run_next_task()
File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line 5329, in
run_next_task
return [task.run(), task.title]
File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line 2453, in
run
raise Exception("Program failed")
Exception: Program failed
I'm using a copy of /usr/local/cado-nfs/params/params.c186 (with extra
settings appended) as the argument to cadofactor.py, which includes
this definition:
alim = 80000000
Using cado-nfs-2.1.1 with the same params file, there are no problems.
Sincerely,
Greg
| Greg Marks |
| Department of Mathematics and Computer Science |
| St. Louis University |
| St. Louis, MO 63103-2007 |
| U.S.A. |
| Phone: (314)977-7206 Fax: (314)977-1452 |
| PGP encryption public key ID: 0x53F269E8 |
| Web: http://gmarks.org |
Message from paul zimmermann <Paul.Zimmermann@inria.fr>
of August 17, 2015, 18:14:39 +0200, follows:
> Greg,
> it seems to work with the git version (just fixed the fact that the command
> line was not printed in c60.freerel.freerel.stdout.1):
> zimmerma@tarte:~/svn/cado-nfs$ ./factor.sh
> 90377629292003121684002147101760858109247336549001090677693
> tasks.sieve.freerel.threads=3
> zimmerma@tarte:~/svn/cado-nfs$ head -1
> /tmp/cado.hDYwnLCKdk/c60.freerel.freerel.stdout.1
> # (747a3bd+) /users/caramel/zimmerma/svn/cado-nfs/build/tarte/sieve/freerel
> -poly /tmp/cado.hDYwnLCKdk/c60.polyselect2.poly -renumber
> /tmp/cado.hDYwnLCKdk/c60.freerel.renumber.gz -lpb0 18 -lpb1 19 -out
> /tmp/cado.hDYwnLCKdk/c60.freerel.freerel.gz -t 3
> Please can you check again (with the latest git version) and report here?
> Paul
> > Date: Sat, 8 Aug 2015 14:05:16 -0500
> > From: Greg Marks <marks@member.ams.org>
> > Dear Paul,
> > Thank you for appended message containing the patch. I did change
> > the dup2.c file as indicated in your message below, and recompiled.
> > The program has been sieving successfully for perhaps a month since
> > then, and I have not encountered this zero-byte problem again. So this
> > probably means that problem is solved.
> > Incidentally, in another message you suggested that one could speed up
> > the free relation calculation when restarting a computation in a fresh
> > working directory with the command:
> > cadofactor.py ... tasks.sieve.freerel.threads=3
> > I've tried this a few times, including with other numbers in place of
> > 3, but the freerel routine uses only one core no matter what I try.
> > Admittedly this isn't that important, since it's only an extra hour
> > or two from time to time in a months-long computation. (There is a
> > sort of psychological reason to want to speed this step along: what's
> > usually happened is that I've deleted some corrupted sieving file and
> > am anxious to see whether las is going to restart without errors.)
> > Sincerely,
> > Greg
> > | Greg Marks |
> > | U.S.A. |
> > of June 29, 2015, 18:03:18 +0200, follows:
> > > > The program now terminates with the error message appended at the
> > > > bottom
> > > > of this message. The file $WORKDIR/c184.duplicates1//0/dup1.1.0000.gz
> > > > mentioned in the stderr below turns out to be a 20 byte file, which,
> > > > when gunzipped, is a zero byte file.
> > > it is a bug that a zero byte file is not accepted in dup2. I fixed this
> > > in
> > > commit 73aa354 (review welcome).
> > > Greg, please could you try again with this change?
> > > --- a/filter/dup2.c
> > > +++ b/filter/dup2.c
> > > @@ -432,11 +432,18 @@ int check_whether_file_is_renumbered(const char *
> > > filename, unsigned int npoly)
> > > unsigned int count = 0;
> > > char s[1024];
> > > FILE *f_tmp = fopen_maybe_compressed (filename, "rb");
> > > if (!f_tmp) {
> > > fprintf(stderr, "%s: %s\n", filename, strerror(errno));
> > > abort();
> > > + if (feof (f_tmp)) /* file is empty */
> > > + fclose_maybe_compressed (f_tmp, filename);
> > > + return 1; /* an empty file might be considered as renumbered */
> > > /* Look for first non-comment line */
> > > while (1) {
> > > char *ret = fgets (s, 1024, f_tmp);
> > > Paul
> > [2:application/pgp-signature Show Save:signature.asc (819B)]
Attachment: signature.asc
Description: Digital signature
