cado-nfs - Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering
  • To: Pierrick Gaudry <pierrick.gaudry@loria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] cado-nfs-2.1.1 crash during filtering
  • Date: Sun, 30 Aug 2015 21:00:25 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=marks@member.ams.org; spf=None smtp.mailfrom=marks@member.ams.org; spf=Pass smtp.helo=postmaster@gmarks.org
  • Ironport-phdr: 9a23:s9DwIxxwVH4lny7XCy+O+j09IxM/srCxBDY+r6Qd0eIXIJqq85mqBkHD//Il1AaPBtWAra0cwLeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStWU0Jz8irj60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGx48sgs/M9YUKj8Y79wDfkBVGxnYCgJ45jTtBTZVwqE5TMzW3gaiAsAVxDE4QvgX5zy9CTzq+ZnyQGeOtf3RPY6Q2Lxwb1sTUrHkioIfxsw6mLMwph1hbhYuzqkqhl1zpSSaYSOcv1kcfWOLpshWWNdU5MJBGR6CYSmYt5KVrJZMA==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Pierrick,
Thank you for your help. You're quite right: I had forgotten to change
the definition of tasks.execpath in my params file to my alternative
build directory, created when I compiled the git version.
Downloading a new git version today, recompiling from scratch, making
sure to use the correct execpath, setting tasks.sieve.freerel.threads=8,
I now get this error:
Error:Generate Free Relations: Program run on server failed with exit code
1
Error:Generate Free Relations: Command line was:
/usr/local/cado-nfs-build-git/sieve/freerel -poly
/tmp/cado.zCGBRfYgj9/c184.polyselect2.poly -renumber
/tmp/cado.zCGBRfYgj9/c184.freerel.renumber.gz -lpbr 32 -lpba 32 -out
/tmp/cado.zCGBRfYgj9/c184.freerel.freerel.gz >
/tmp/cado.zCGBRfYgj9/c184.freerel.freerel.stdout.1 2>
/tmp/cado.zCGBRfYgj9/c184.freerel.freerel.stderr.1
Error:Generate Free Relations: Stderr output follows (stored in file
/tmp/cado.zCGBRfYgj9/c184.freerel.freerel.stderr.1):
b'# Warning: parameter verbose_flags is checked by this program but is
undocumented.\nError, missing -lpbr or -lpba command line argument\nUsage:
/usr/local/cado-nfs-build-git/sieve/freerel <parameters>\nThe available
parameters are the following:\n -poly input polynomial file\n
-renumber output file for renumbering table\n -out output file for
free relations\n -lpb0 large prime bound on side 0\n -lpb1
large prime bound on side 1\n -pmin do not create freerel below this
bound\n -pmax do not create freerel beyond this bound\n -badideals
file describing bad ideals (for DL)\n -addfullcol (switch) add a column of
1 in the matrix (for DL)\n -t number of threads\n'
Traceback (most recent call last):
File "/usr/local/cado-nfs-2.1.1/scripts/cadofactor/cadofactor.py", line
72, in <module>
factors = factorjob.run()
File "/usr/local/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line
4720, in run
last_status, last_task = self.run_next_task()
4788, in run_next_task
return [task.run(), task.title]
2367, in run
raise Exception("Program failed")
Exception: Program failed
This is running with Linux Centos 6 x86_64. Reverting to cado-nfs-2.1.1,
I have no problems.
Sincerely,
Greg
| Greg Marks |
| Department of Mathematics and Computer Science |
| St. Louis University |
| St. Louis, MO 63103-2007 |
| U.S.A. |
| Phone: (314)977-7206 Fax: (314)977-1452 |
| PGP encryption public key ID: 0x53F269E8 |
| Web: http://gmarks.org |
Message from Pierrick Gaudry <pierrick.gaudry@loria.fr>
of August 19, 2015, 08:40:04 +0200, follows:
> It seems that you used a new cadofactor script with an old makefb binary.
> I suggest that you recompile everything from scratch with the new
> downloaded version.
> Also, there are currently many changes occurring in the git version,
> sometimes breaking everything. It is highly recommended to check on
> https://ci.inria.fr/cado/
> to see if there are failures with the current git version for your
> architecture / OS. For instance, at the time of writing this message, it
> is a very bad idea to git pull if you have a Mac.
> Pierrick
> On Tue, Aug 18, 2015 at 11:57:50PM -0500, Greg Marks wrote:
> > Dear Paul,
> > I'm encountering into a problem with the git version, downloaded today
> > from here:
> > git clone
> > https://scm.gforge.inria.fr/anonscm/git/cado-nfs/cado-nfs.git
> > Running the program with the same parameter settings as before, it
> > terminates with this error:
> > Info:Generate Factor Base: Starting
> > Warning:Command: Process with PID 9943 finished with return code 1
> > Error:Generate Factor Base: Program run on server failed with exit
> > code 1
> > Error:Generate Factor Base: Command line was:
> > /usr/local/cado-nfs-build/sieve/makefb -poly
> > /tmp/cado.zCGBRfYgj9/c184.polyselect2.poly -lim 80000000 -maxbits 14 -out
> > /tmp/cado.zCGBRfYgj9/c184.factorbase.roots.gz -t 8 >
> > /tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stdout.1 2>
> > /tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stderr.1
> > Error:Generate Factor Base: Stderr output follows (stored in file
> > /tmp/cado.zCGBRfYgj9/c184.factorbase.makefb.stderr.1):
> > b'Error: parameter -alim is mandatory\nUsage:
> > /usr/local/cado-nfs-build/sieve/makefb <parameters>\nThe available
> > parameters are the following:\n -poly polynomial file\n -alim
> > factor base bound\n -maxbits (optional) maximal number of bits
> > of powers\n -out (optional) name of the output file\n -side
> > (optional) create factor base for given side. Side must be 0 or 1
> > (default is 1, i.e. algebraic).\n'
> > File "/usr/local/cado-nfs/scripts/cadofactor/cadofactor.py", line
> > 81, in <module>
> > File "/usr/local/cado-nfs/scripts/cadofactor/cadotask.py", line
> > 5251, in run
> > 5329, in run_next_task
> > 2453, in run
> > I'm using a copy of /usr/local/cado-nfs/params/params.c186 (with extra
> > settings appended) as the argument to cadofactor.py, which includes
> > this definition:
> > alim = 80000000
> > Using cado-nfs-2.1.1 with the same params file, there are no problems.
> > Sincerely,
> > Greg
> > | Greg Marks |
> > | U.S.A. |
> > Message from paul zimmermann <Paul.Zimmermann@inria.fr>
> > of August 17, 2015, 18:14:39 +0200, follows:
> > > Greg,
> > > it seems to work with the git version (just fixed the fact that the
> > > command
> > > line was not printed in c60.freerel.freerel.stdout.1):
> > > zimmerma@tarte:~/svn/cado-nfs$ ./factor.sh
> > > 90377629292003121684002147101760858109247336549001090677693
> > > tasks.sieve.freerel.threads=3
> > > zimmerma@tarte:~/svn/cado-nfs$ head -1
> > > /tmp/cado.hDYwnLCKdk/c60.freerel.freerel.stdout.1
> > > # (747a3bd+)
> > > /users/caramel/zimmerma/svn/cado-nfs/build/tarte/sieve/freerel -poly
> > > /tmp/cado.hDYwnLCKdk/c60.polyselect2.poly -renumber
> > > /tmp/cado.hDYwnLCKdk/c60.freerel.renumber.gz -lpb0 18 -lpb1 19 -out
> > > /tmp/cado.hDYwnLCKdk/c60.freerel.freerel.gz -t 3
> > > Please can you check again (with the latest git version) and report
> > > here?
> > > Paul
> > > > Date: Sat, 8 Aug 2015 14:05:16 -0500
> > > > From: Greg Marks <marks@member.ams.org>
> > > > Dear Paul,
> > > > Thank you for appended message containing the patch. I did change
> > > > the dup2.c file as indicated in your message below, and recompiled.
> > > > The program has been sieving successfully for perhaps a month since
> > > > then, and I have not encountered this zero-byte problem again. So
> > > > this
> > > > probably means that problem is solved.
> > > > Incidentally, in another message you suggested that one could speed up
> > > > the free relation calculation when restarting a computation in a fresh
> > > > working directory with the command:
> > > > cadofactor.py ... tasks.sieve.freerel.threads=3
> > > > I've tried this a few times, including with other numbers in place of
> > > > 3, but the freerel routine uses only one core no matter what I try.
> > > > Admittedly this isn't that important, since it's only an extra hour
> > > > or two from time to time in a months-long computation. (There is a
> > > > sort of psychological reason to want to speed this step along: what's
> > > > usually happened is that I've deleted some corrupted sieving file and
> > > > am anxious to see whether las is going to restart without errors.)
> > > > Sincerely,
> > > > Greg
> > > > | Greg Marks |
> > > > | U.S.A. |
> > > > of June 29, 2015, 18:03:18 +0200, follows:
> > > > > > The program now terminates with the error message appended at the
> > > > > > bottom
> > > > > > of this message. The file
> > > > > > $WORKDIR/c184.duplicates1//0/dup1.1.0000.gz
> > > > > > mentioned in the stderr below turns out to be a 20 byte file,
> > > > > > which,
> > > > > > when gunzipped, is a zero byte file.
> > > > > it is a bug that a zero byte file is not accepted in dup2. I fixed
> > > > > this in
> > > > > commit 73aa354 (review welcome).
> > > > > Greg, please could you try again with this change?
> > > > > --- a/filter/dup2.c
> > > > > +++ b/filter/dup2.c
> > > > > @@ -432,11 +432,18 @@ int check_whether_file_is_renumbered(const
> > > > > char * filename, unsigned int npoly)
> > > > > unsigned int count = 0;
> > > > > char s[1024];
> > > > > FILE *f_tmp = fopen_maybe_compressed (filename, "rb");
> > > > > if (!f_tmp) {
> > > > > fprintf(stderr, "%s: %s\n", filename, strerror(errno));
> > > > > abort();
> > > > > + if (feof (f_tmp)) /* file is empty */
> > > > > + fclose_maybe_compressed (f_tmp, filename);
> > > > > + return 1; /* an empty file might be considered as
> > > > > renumbered */
> > > > > /* Look for first non-comment line */
> > > > > while (1) {
> > > > > char *ret = fgets (s, 1024, f_tmp);
> > > > > Paul
> > > > [2:application/pgp-signature Show Save:signature.asc (819B)]
> > _______________________________________________
> > Cado-nfs-discuss mailing list
> > Cado-nfs-discuss@lists.gforge.inria.fr
> > http://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
Attachment: signature.asc
Description: Digital signature
