- To: paul zimmermann <Paul.Zimmermann@inria.fr>, cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] [error] Failed on the filtering step.
- Date: Thu, 26 Jul 2018 14:12:08 +0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-vk0-f41.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi, i've tried your suggestion about restarting it from the scratch by importing the previously calculated relations. As i have seen it, the relations target seems to increase twofold as i add both lpb with 1. Is this normal?
Kamis, 26 Juli 2018, canny georgina <cannysiska@gmail.com> menulis:
if i import the relations, then that means the CPU time computed for lattice sieving (at the end of computation) will be counted only from the rest of the relations that hasn't been collected, right? I mean, the CPU time will not be calculated from the start again right?2018-07-26 12:48 GMT+07:00 paul zimmermann <Paul.Zimmermann@inria.fr>:Dear canny georgina,
you might try to increase lpb (as was already suggested to you), but this is
not guaranteed to work, since you are outside the normal usage of cado-nfs.
If that does not work, you should restart from scratch with larger lpbs,
while importing the already computed relations.
Paul Zimmermann
- [Cado-nfs-discuss] [error] Failed on the filtering step., canny georgina, 07/26/2018
- Re: [Cado-nfs-discuss] [error] Failed on the filtering step., paul zimmermann, 07/26/2018
- Message not available
- Re: [Cado-nfs-discuss] [error] Failed on the filtering step., canny georgina, 07/26/2018
- [Cado-nfs-discuss] Fwd: [error] Failed on the filtering step., canny georgina, 07/26/2018
- Re: [Cado-nfs-discuss] Fwd: [error] Failed on the filtering step., paul zimmermann, 07/26/2018
