cado-nfs - [Cado-nfs-discuss] Fwd: [error] Failed on the filtering step.
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Fwd: [error] Failed on the filtering step.
  • Date: Thu, 26 Jul 2018 15:44:03 +0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-ua0-f173.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
if i import the relations, then that means the CPU time computed for lattice sieving (at the end of computation) will be counted only from the rest of the relations that hasn't been collected, right? I mean, the CPU time will not be calculated from the start again right?
