cado-nfs - Re: [cado-nfs] Unexpected Memory Use Change
  • To: Ed Hall <ed_ka2fwj@yahoo.com>
  • Cc: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
  • Subject: Re: [cado-nfs] Unexpected Memory Use Change
  • Date: Tue, 6 Apr 2021 15:26:33 +0200
  • Ironport-hdrordr: A9a23:YoqJN6CSywBLe2PlHekl55DYdL4zR+YMi2QD/UoZc3BoW+afkN2jm+le+B/vkTAKWGwhn9foAtjjfVr385lp7Y4NeYq4VA79t2eyaK1k543uwzrvcheOk9J1/6FmbqR4FZnMHUF35PyKgzWQPt48zLC8m5yAqvzZyx5WJz1CS6Yl1AthDxbeL0sefngjObMcNL6xovVKvCChf3N/VKSGL10IRfLKqdGOtL+OW3A7LiUq4gWPkj+kgYSSeySw5RsQXyhCxr0v6wH+8jDR3LmpsP2w13bnuFP70pI+orbc9uc=
On Tue, Apr 06, 2021 at 01:24:04PM +0000, Ed Hall wrote:
> Dear Emmanuel,
> Thank you for your quick reply.
> I'm posting the original poly, snfs params and the latest snapshot, since
> many alterations have been made to the snapshots along the way.
> I tried to swap the strategy by a client call and it was not accepted.  Do
> I need to restart the server to do this? It would take a while to filter
> through to the assigned WUs:
> $ ./cado-nfs-client.py --clientid=test --single --bindir=build/$HOSTNAME/
> --override t 6 --adjust-strategy 0 --server=http://math99.local:13573
> Usage: cado-nfs-client.py [options]
> cado-nfs-client.py: error: no such option: --adjust-strategy
You should rather use:
--override adjust-strategy 0
Yes, the way --override works (when it works...) is quirky.
E.
> }}}}}}}}}} Original polynomial:
> n:
> 481656163308412765403614651218708598794359189399756146690661073869112900839012131985010061499036900388686771640446175627690737806643304133900246206450098561588920335412290847983165259494228429323278741
> skew: 2.592
> c8: 81
> c7: 810
> c6: 1890
> c5: -5400
> c4: -28800
> c3: -27000
> c2: 36000
> c1: 60000
> c0: 10000
> Y1: 43046721000000000000000
> Y0: -10000000000000000617673396283947
> }}}}}}}}}} snfs params file:
> #     Parameter file for Cado-NFS
> # See params/params.c90 for an example which contains some documentation.
> # General parameters
> name = hcn10+3_930
> N =
> # Polynomial selection
> tasks.polyselect.admin = 0
> tasks.polyselect.admax = 0
> tasks.polyselect.adrange = 0
> tasks.polyselect.import = 10+3_930.poly
> # Sieve
> tasks.I = 15
> tasks.qmin = 1000000
> tasks.lim0 = 536000000
> tasks.lim1 = 536000000
> tasks.lpb0 = 32
> tasks.lpb1 = 32
> tasks.sieve.mfb0 = 64
> tasks.sieve.mfb1 = 94
> tasks.sieve.lambda0 = 2.8
> tasks.sieve.lambda1 = 2.8
> tasks.sieve.ncurves0 = 12
> tasks.sieve.ncurves1 = 8
> tasks.sieve.qrange = 5000
> tasks.sieve.sqside = 1
> tasks.sieve.rels_wanted = 200000000
> # Filtering
> tasks.filter.purge.keep = 160
> tasks.filter.target_density = 170.0
> # Linear algebra
> tasks.linalg.bwc.interval = 1000
> tasks.linalg.bwc.interleaving = 0
> tasks.linalg.m = 64
> tasks.linalg.n = 64
> # Characters
> tasks.linalg.characters.nchar = 50
> }}}}}}}}}} Latest snapshot:
> N =
> name = hcn10+3_930
> server.port = 13573
> server.ssl = no
> server.whitelist = 1.1.1.98,1.1.1.99,192.168.0.0/24
> slaves.basepath = /home/math99/Math/snfsTesting/10+3_930/client
> tasks.I = 15
> tasks.execpath = /home/math99/Math/cado-nfs/build/math99
> tasks.lpb0 = 32
> tasks.lpb1 = 32
> tasks.threads = 24
> tasks.workdir = /home/math99/Math/snfsTesting/10+3_930
> tasks.linalg.m = 64
> tasks.linalg.n = 64
> tasks.linalg.bwc.cpubinding =
> /home/math99/Math/cado-nfs/parameters/misc/cpubinding.conf
> tasks.linalg.bwc.threads = 12
> tasks.polyselect.threads = 2
> tasks.sieve.adjust_strategy = 2
> tasks.sieve.ncurves0 = 20
> tasks.sieve.ncurves1 = 20
> tasks.sieve.qrange = 2000
> tasks.sieve.rels_wanted = 700000000
> tasks.sieve.las.threads = 2
> tasks.sqrt.threads = 8
> I'm building commit dc9309189 currently and will have some files in a bit.
> Thanks for all the work.
> Sincerely,
> Edwin Hall
