- To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
- Cc: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
- Subject: Re: [cado-nfs] Unexpected Memory Use Change
- Date: Tue, 6 Apr 2021 15:08:20 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ed_ka2fwj@yahoo.com; spf=Pass smtp.mailfrom=ed_ka2fwj@yahoo.com; spf=None smtp.helo=postmaster@sonic317-26.consmr.mail.bf2.yahoo.com
- Ironport-hdrordr: A9a23:KL7JY6qUAdDsjb7GD3xbZyUaV5t6L9V00zAX/kB9WHVpW+aT/vre/8gz/xnylToXRTUEldePJajoewKmybde544NMbC+GDT3oWfAFvAa0aLO4R3FXxf/+OlUyLt6f8FFY+HYIFBmga/BjjWQPM0nxLC8kZyApeCb9Ht1SBEvVqcI1XYdNi++MmlbADZLHoA4Ep303LsgmxOFdW4MZsq2QlkpNtKzxeHjr57tbR4YCxNP0mDn4g+A07L0HwOV2R0TSVp0sNMf2FLYmA/07LjLiYDd9jbg0Qboj6h+qZ/EwttHCNfksLlsFhzczjyPQ6RKH5ChnBRwmsGAzz8R+uXkklMbOcNy4Tf0UQiOzSfF6k3R9D4v7jvF83HwuxbenfA=
- Ironport-phdr: A9a23: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
Could you report on what happens in each of the following situations:
- current HEAD, but with --adjust-strategy 0
Here is the result, with the attached relations file:
commit 1d08d4325615139dbe007b43b31e734c4b7dec8d (HEAD -> master, origin/master, origin/HEAD)
Merge: 60f1fe069 0b8ff834d
Author: Emmanuel Thom� <emmanuel.thome@inria.fr>
Date: Sun Apr 4 19:55:46 2021 +0000
Merge branch 'lean-ci' into 'master'
simplify ci structure, get rid of intermediary containers.
See merge request cado-nfs/cado-nfs!30
$ ./cado-nfs-client.py --clientid=test --single --bindir=build/$HOSTNAME/ --override t 6 --override adjust-strategy 0 --server=http://math99.local:13573
INFO:root:Running build/math89/sieve/las -poly download/hcn10+3_930.poly -q0 540548000 -I 15 -q1 540550000 -lim0 536000000 -lim1 536000000 -lpb0 32 -lpb1 32 -mfb0 64 -mfb1 94 -ncurves0 20 -ncurves1 20 -fb1 download/hcn10+3_930.roots1.gz -out test.work/hcn10+3_930.540548000-540550000.gz -t 6 -sqside 1 -adjust-strategy 0 -stats-stderr
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
20203 math89 20 0 3649112 3.2g 7272 S 553.2 20.4 49:33.76 las
Thanks,
Ed
hcn10+3_930.540548000-540550000.t8gwen0n.gz
Description: application/gzip
- [cado-nfs] Unexpected Memory Use Change, Ed Hall, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Emmanuel Thomé, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Ed Hall, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Paul Zimmermann, 04/06/2021
