- To: Ed Hall <ed_ka2fwj@yahoo.com>
- Cc: Emmanuel.Thome@inria.fr, cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Unexpected Memory Use Change
- Date: Tue, 06 Apr 2021 15:31:06 +0200
- Ironport-hdrordr: A9a23:LbcZNaG2YdTwo/l/pLqEP8eALOonbusQ8zAX/mp2TgFYddHdqtunm+4V2QSxpDEaXnwhnt7oAsm9aFnb8oN45pRUAKe6UGDd2VeAAYl+4eLZrwHINDb58odmv5tIV4hbJJnOAUNhjcD8iTPXL/8FzMOc+K6lwcfSpk0DcShQZ6tt7xh0B2+geyVLbTNbDpk0Hof03Kd6jgenEE59UviG
Dear Ed,
to investigate the issue, you only need to re-run a single "las" workunit,
say with -t 6. For that, simply copy the command line at the beginning of
a successful las run (cf download/*gz), and add --adjust-strategy 0 or so.
Best regards,
Paul
- [cado-nfs] Unexpected Memory Use Change, Ed Hall, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Emmanuel Thomé, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Ed Hall, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Paul Zimmermann, 04/06/2021
