- To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
- Cc: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
- Subject: Re: [cado-nfs] Unexpected Memory Use Change
- Date: Tue, 6 Apr 2021 14:27:51 +0000 (UTC)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ed_ka2fwj@yahoo.com; spf=Pass smtp.mailfrom=ed_ka2fwj@yahoo.com; spf=None smtp.helo=postmaster@sonic304-9.consmr.mail.bf2.yahoo.com
- Ironport-hdrordr: A9a23:moZAca+UphKOIVteZahuk+BSI+orLtY04lQ7vn1ZYxpTb8CeioSSjO0WvCWetB89elEF3eqBNq6JXG/G+fdOi7U5EL++UGDdyQ+VBa5464+K+VzdMgj/7PMY6aB7b6NlAsbxBlQSt7ee3CCdM/INhOaK67qpg+C29QYLcShPZ7t75wl0Tia3e3cGJjVuPpYyGJqC6scvnVPJRV0scs+5CnMZNtKzxOHjqZSOW347Li9iwgGLlDup5rmSKXel9yZbeTZOzbA+mFKoryXJooGqs/S20XbnulP73tBonMboo+EsOPCx
- Ironport-phdr: A9a23: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
"Could you report on what happens in each of the following situations:
- commit dc9309189 (before the fix of #30012)
Here is the info for commit dc9309189:
commit dc9309189e0bc51b39dbf6dd9d1330d3fd43e2af (HEAD)
Author: Emmanuel Thom� <Emmanuel.Thome@inria.fr>
Date: Wed Mar 17 19:08:16 2021 +0100
fix buggy dereference
20032 math89 20 0 4386416 3.9g 7156 S 577.2 25.0 17:59.04 las
$ ./cado-nfs-client.py --clientid=test --single --bindir=build/$HOSTNAME/ --override t 6 --server=http://math99.local:13573
INFO:root:Running build/math89/sieve/las -poly download/hcn10+3_930.poly -q0 540314000 -I 15 -q1 540316000 -lim0 536000000 -lim1 536000000 -lpb0 32 -lpb1 32 -mfb0 64 -mfb1 94 -ncurves0 20 -ncurves1 20 -fb1 download/hcn10+3_930.roots1.gz -out test.work/hcn10+3_930.540314000-540316000.gz -t 6 -sqside 1 -adjust-strategy 2 -stats-stderr
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 20032 math89 20 0 4386416 3.9g 7156 S 577.2 25.0 17:59.04 las
I have attached the relations file.
Thanks,
Ed
hcn10+3_930.540314000-540316000.4vtmt5sm.gz
Description: application/gzip
- [cado-nfs] Unexpected Memory Use Change, Ed Hall, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Emmanuel Thomé, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Ed Hall, 04/06/2021
- Re: [cado-nfs] Unexpected Memory Use Change, Paul Zimmermann, 04/06/2021
