- To:
- Subject: Re: [cgal-discuss] 2D segment-circle intersection?
- Date: Wed, 03 Jan 2007 10:36:30 +0100
Hi,
You can use CircularKernel::Intersect_2, that computes the intersections.
Not the best possible way to answer your question, though. It seems that the predicate Do_intersect_2 does not handle segment and circle. To be added...
Best
Monique Teillaud
Malcolm Ryan wrote:
Is there any simple way for me to determine whether a Segment intersects with a Circle in 2D?
Malcolm
--- You are currently subscribed to cgal-discuss.
- 2D segment-circle intersection?, Malcolm Ryan, 01/03/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Monique Teillaud, 01/03/2007
- 3d lines intersection point, Cédric LE MAITRE, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Andreas Fabri, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Vikas, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Hua Lu, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/05/2007
- Re: [cgal-discuss] 3d lines intersection point, Monique Teillaud, 01/04/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/29/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/30/2007
